Qué necesitas
Remove the rubber inserts inside the the two purple feet located on the router's front case.
This may be a challenge, so try the following two methods:
Use a plastic opening tool. Insert the flat end of the tool into the seam and slowly pry the rubber feet out.
Use a metal spudger. Insert the point of the metal spudger directly into the hole of the rubber feet and pry the insert out.
Removing the router's rear case is the same as removing the motherboard, since the two parts are attached to each other.
Once you complete this step, your router will be completely disassembled.
