Saltar al contenido principal
Linksys WAP54g LED Lights Replacement
Qué necesitas
  1. Linksys WAP54g LED Lights Replacement, Top Casing: paso 1, imagen 1 de 1
    • Power down and unplug the device.
  2. Linksys WAP54g LED Lights Replacement: paso 2, imagen 1 de 1
  3. Linksys WAP54g LED Lights Replacement: paso 3, imagen 1 de 1
    • Remove the two black rubber feet of the device using the screwdriver. The feet are located on the bottom towards the front.
  4. Linksys WAP54g LED Lights Replacement: paso 4, imagen 1 de 1
    • Once the feet are removed, two small screws will be visible. With a small screwdriver, unscrew them. Screws are phillips head, 4.35 mm in diameter, 7.88 mm in length.
  5. Linksys WAP54g LED Lights Replacement: paso 5, imagen 1 de 1
    • To remove the front blue panel, grip firmly and place thumbs in the two notches on top. Push thumbs forward while keeping a firm grip on bottom.
    • This may require a bit of force.
  6. Linksys WAP54g LED Lights Replacement: paso 6, imagen 1 de 1
    • Now slide the bottom panel forward and remove it so the top casing is isolated from the bottom casing and motherboard.
  7. Linksys WAP54g LED Lights Replacement: paso 7, imagen 1 de 2 Linksys WAP54g LED Lights Replacement: paso 7, imagen 2 de 2
    • Unscrew the nut on the outer side of the back casing. Remove the nut and the washer from both antenna mounts.
  8. Linksys WAP54g LED Lights Replacement: paso 8, imagen 1 de 2 Linksys WAP54g LED Lights Replacement: paso 8, imagen 2 de 2
    • From here, remove the wires and nuts connected to the back panel by pulling the nuts through the holes.
    • Now the top casing has been removed and isolated from the rest of the device. From here, you can make repairs to the top casing.
    • Once the top panel is removed the main board will still be attached to the bottom panel.
  9. Linksys WAP54g LED Lights Replacement, Bottom Casing/Motherboard: paso 9, imagen 1 de 2 Linksys WAP54g LED Lights Replacement, Bottom Casing/Motherboard: paso 9, imagen 2 de 2
    • Unscrew the two screws that connect the motherboard to the bottom casing.
    • The motherboard and bottom casing should be completely separated at this point. This allows for replacement of the motherboard and/ or its components as well as the bottom casing.
  10. Linksys WAP54g LED Lights Replacement, LED Lights: paso 10, imagen 1 de 1
    • Using a soldering iron, desolder the LED lights from the bottom of the logic board.
    • For help with soldering or desoldering refer to ifixit's soldering guide: Cómo soldar y desoldar conexiones
  11. Linksys WAP54g LED Lights Replacement: paso 11, imagen 1 de 1
    • Place new LED lights through holes created by desoldering and removing old lights.
  12. Linksys WAP54g LED Lights Replacement: paso 12, imagen 1 de 2 Linksys WAP54g LED Lights Replacement: paso 12, imagen 2 de 2
    • Solder the lights onto the bottom of the board to solidify the connection and make electrical contact.
    • Follow the Installing the Casing guide in reverse to re-assemble your device.
Conclusión
Once the soldering is complete, the device should work and the LED lights should light up.
Una persona más ha completado esta guía.
Derek Myers
Miembro Desde 10/04/11
288 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 21-21, Maness Fall 2011 Miembro de Cal Poly, Team 21-21, Maness Fall 2011
CPSU-MANESS-F11S21G21
5 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 12
Todo El Tiempo: 2,058
