Introducción
You will start by isolating the motherboard and then continue to make the suggested repairs by soldering.
Qué necesitas
Remove the antennas from the back of the device. To do this, follow steps 1 and 2 of Installing the Antennas Guide: Linksys WAP54g Antennas Replacement
Unscrew the two screws that connect the motherboard to the bottom casing.
Using a soldering iron, desolder the LED lights from the bottom of the logic board.
For help with soldering or desoldering refer to ifixit's soldering guide: Cómo soldar y desoldar conexiones
Once the soldering is complete, the device should work and the LED lights should light up.
Una persona más ha completado esta guía.
