Saltar al contenido principal
Linksys WAP54g Bottom Casing/Motherboard Replacement
Qué necesitas
  1. Linksys WAP54g Bottom Casing/Motherboard Replacement, Top Casing: paso 1, imagen 1 de 1
    • Power down and unplug the device.
  2. Linksys WAP54g Bottom Casing/Motherboard Replacement: paso 2, imagen 1 de 1
  3. Linksys WAP54g Bottom Casing/Motherboard Replacement: paso 3, imagen 1 de 1
    • Remove the two black rubber feet of the device using the screwdriver. The feet are located on the bottom towards the front.
  4. Linksys WAP54g Bottom Casing/Motherboard Replacement: paso 4, imagen 1 de 1
    • Once the feet are removed, two small screws will be visible. With a small screwdriver, unscrew them. Screws are phillips head, 4.35 mm in diameter, 7.88 mm in length.
  5. Linksys WAP54g Bottom Casing/Motherboard Replacement: paso 5, imagen 1 de 1
    • To remove the front blue panel, grip firmly and place thumbs in the two notches on top. Push thumbs forward while keeping a firm grip on bottom.
    • This may require a bit of force.
  6. Linksys WAP54g Bottom Casing/Motherboard Replacement: paso 6, imagen 1 de 1
    • Now slide the bottom panel forward and remove it so the top casing is isolated from the bottom casing and motherboard.
  7. Linksys WAP54g Bottom Casing/Motherboard Replacement: paso 7, imagen 1 de 2 Linksys WAP54g Bottom Casing/Motherboard Replacement: paso 7, imagen 2 de 2
    • Unscrew the nut on the outer side of the back casing. Remove the nut and the washer from both antenna mounts.
  8. Linksys WAP54g Bottom Casing/Motherboard Replacement: paso 8, imagen 1 de 2 Linksys WAP54g Bottom Casing/Motherboard Replacement: paso 8, imagen 2 de 2
    • From here, remove the wires and nuts connected to the back panel by pulling the nuts through the holes.
    • Now the top casing has been removed and isolated from the rest of the device. From here, you can make repairs to the top casing.
    • Once the top panel is removed the main board will still be attached to the bottom panel.
  9. Linksys WAP54g Bottom Casing/Motherboard Replacement, Bottom Casing/Motherboard: paso 9, imagen 1 de 2 Linksys WAP54g Bottom Casing/Motherboard Replacement, Bottom Casing/Motherboard: paso 9, imagen 2 de 2
    • Unscrew the two screws that connect the motherboard to the bottom casing.
    • The motherboard and bottom casing should be completely separated at this point. This allows for replacement of the motherboard and/ or its components as well as the bottom casing.
Conclusión
After the motherboard is isolated component level repairs can be made.
2 personas más completaron esta guía.
Mathew Fuller
Miembro Desde 10/04/11
146 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 21-21, Maness Fall 2011 Miembro de Cal Poly, Team 21-21, Maness Fall 2011
CPSU-MANESS-F11S21G21
5 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 11
Todo El Tiempo: 2,593
