Saltar al contenido principal
Linksys WAP54g Antennas Replacement
  1. Linksys WAP54g Antennas Replacement, Antennas: paso 1, imagen 1 de 2 Linksys WAP54g Antennas Replacement, Antennas: paso 1, imagen 2 de 2
    • Make sure the antennas are in a straight position, not bent, to remove the black casing.
    • Remove the casing by pulling straight up. This will make unscrewing the antenna easier.
  2. Linksys WAP54g Antennas Replacement: paso 2, imagen 1 de 1
    • Grip antenna at the base and twist counter-clockwise to unscrew it from the device. The base should have a rough feel to it.
  3. Linksys WAP54g Antennas Replacement: paso 3, imagen 1 de 1
    • Once antenna is completely detached, obtain the new antenna, and place it on device so the threads line up.
  4. Linksys WAP54g Antennas Replacement: paso 4, imagen 1 de 1
    • Screw antenna onto device by twisting the base of the antenna in a clockwise motion until it is tight and does not turn any further.
  5. Linksys WAP54g Antennas Replacement: paso 5, imagen 1 de 1
    • Place the black casing, which was removed in step 1, back onto the base of the antenna to cover up exposed metal.
    • Repeat these steps for other antenna.
Conclusión
After the repairs are made the device should working.
2 personas más completaron esta guía.
Derek Myers
Miembro Desde 10/04/11
288 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 21-21, Maness Fall 2011 Miembro de Cal Poly, Team 21-21, Maness Fall 2011
CPSU-MANESS-F11S21G21
5 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 14
Todo El Tiempo: 2,576
