Saltar al contenido principal
Linksys EA9200 Antenna Port Replacement
Qué necesitas
  1. Linksys EA9200 Antenna Port  Replacement, Linksys EA9200 Disassembly: paso 1, imagen 1 de 2 Linksys EA9200 Antenna Port  Replacement, Linksys EA9200 Disassembly: paso 1, imagen 2 de 2
    • Remove the sticker on the bottom.
    • Remove the two screws holding the bottom plate in place. Use Phillips screwdriver tip #1 , the screw head-size is 5mm.
  2. Linksys EA9200 Antenna Port  Replacement: paso 2, imagen 1 de 2 Linksys EA9200 Antenna Port  Replacement: paso 2, imagen 2 de 2
    • Remove the back sticker that has all the labels.
    • There are two screws to remove. They are 6mm in diameter, use phillips screw tip #1.
  3. Linksys EA9200 Antenna Port  Replacement: paso 3, imagen 1 de 3 Linksys EA9200 Antenna Port  Replacement: paso 3, imagen 2 de 3 Linksys EA9200 Antenna Port  Replacement: paso 3, imagen 3 de 3
    • Depress the 12 clips along the edge into the router. Use the nylon spudger as using a metal object could cause damage.
  4. Linksys EA9200 Antenna Port  Replacement: paso 4, imagen 1 de 3 Linksys EA9200 Antenna Port  Replacement: paso 4, imagen 2 de 3 Linksys EA9200 Antenna Port  Replacement: paso 4, imagen 3 de 3
    • Once you have one side open, keep a spudger wedged between both sides. This will help keep it open in case it tries to snap back together.
    • These clips are tough and may need some additional force.
  5. Linksys EA9200 Antenna Port  Replacement: paso 5, imagen 1 de 3 Linksys EA9200 Antenna Port  Replacement: paso 5, imagen 2 de 3 Linksys EA9200 Antenna Port  Replacement: paso 5, imagen 3 de 3
    • Lift the board and pull down, away from the antennas.
  6. Linksys EA9200 Antenna Port  Replacement, Antenna Port: paso 6, imagen 1 de 2 Linksys EA9200 Antenna Port  Replacement, Antenna Port: paso 6, imagen 2 de 2
    • The antenna ports are connected to the board with a wire that has a "snap" connector.
  7. Linksys EA9200 Antenna Port  Replacement: paso 7, imagen 1 de 2 Linksys EA9200 Antenna Port  Replacement: paso 7, imagen 2 de 2
    • Desolder the four pins of the antenna port.
    • Do not place the soldering iron on the wrong terminals as this can cause the device to no longer to function.
    • Cómo soldar y desoldar conexiones is iFixit's official guide on how to use a soldering iron
    • You will need a soldering iron that is capable of reaching temperatures greater than 300 degrees Fahrenheit.
    • Temperature of the component will be very hot when desoldered, take precaution when handling.
  8. Linksys EA9200 Antenna Port  Replacement: paso 8, imagen 1 de 1
    • Once the solder is melted, quickly pull broken antenna port.
Conclusión
Shane Davis
Miembro Desde 10/05/16
374 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 9-1, Lacy Fall 2016 Miembro de USF Tampa, Team 9-1, Lacy Fall 2016
USFT-LACY-F16S9G1
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 9
Todo El Tiempo: 804
