Saltar al contenido principal
Linksys EA6900 Router Reset Button Replacement
Qué necesitas
  1. Linksys EA6900 Router Reset Button Replacement, Linksys EA6900 Disassembly: paso 1, imagen 1 de 3 Linksys EA6900 Router Reset Button Replacement, Linksys EA6900 Disassembly: paso 1, imagen 2 de 3 Linksys EA6900 Router Reset Button Replacement, Linksys EA6900 Disassembly: paso 1, imagen 3 de 3
    • Remove the antennas by unscrewing them from the base.
    • Flip over the device and locate the four rubber feet on the bottom.
    • Remove the rubber feet with tweezers
  2. Linksys EA6900 Router Reset Button Replacement: paso 2, imagen 1 de 1
    • Remove the 0.4cm head screws from each slot with the #1 Phillips head Screwdriver.
  3. Linksys EA6900 Router Reset Button Replacement: paso 3, imagen 1 de 1
    • Use a blue plastic opening tool to remove the top cover.
    • Move the blue plastic opening tool gently underneath the top cover from side to side.
  4. Linksys EA6900 Router Reset Button Replacement: paso 4, imagen 1 de 3 Linksys EA6900 Router Reset Button Replacement: paso 4, imagen 2 de 3 Linksys EA6900 Router Reset Button Replacement: paso 4, imagen 3 de 3
    • Gently lift the motherboard and remove it from the case
    • Put the motherboard over a (preferably white) surface.
  5. Linksys EA6900 Router Reset Button Replacement, Router Reset Button: paso 5, imagen 1 de 2 Linksys EA6900 Router Reset Button Replacement, Router Reset Button: paso 5, imagen 2 de 2
    • Make sure to correctly identify the red router reset button.
    • Locate the four solder points on the other side of the motherboard.
  6. Linksys EA6900 Router Reset Button Replacement: paso 6, imagen 1 de 2 Linksys EA6900 Router Reset Button Replacement: paso 6, imagen 2 de 2
    • Be careful when working with the hot soldering iron! Make sure the router motherboard is safely resting on a level and sturdy surface.
    • Carefully apply the soldering iron to the four solders. Avoid touching the motherboard with the soldering iron, this could damage the circuits.
    • Use a spudger to gently pry and remove the reset button once the solder has melted.
Conclusión
4 personas más completaron esta guía.
Rick Hsu
Miembro Desde 09/15/16
343 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 11-1, Blackwell Fall 2016 Miembro de USF Tampa, Team 11-1, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G1
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 1,391
