Saltar al contenido principal
Lifetime 4-Foot Adjustable Table Leg Replacement
Qué necesitas
  1. Lifetime 4-Foot Adjustable Table Leg Replacement, Leg: paso 1, imagen 1 de 3 Lifetime 4-Foot Adjustable Table Leg Replacement, Leg: paso 1, imagen 2 de 3 Lifetime 4-Foot Adjustable Table Leg Replacement, Leg: paso 1, imagen 3 de 3
    • Use the 6 mm Flathead screwdriver to remove the four aluminum slotted screws located on the edges of the table.
    • Use a 5/32" Allen Wrench or 19 mm wrench to remove the two stainless 8-18 steel hex screws from the braces of the table.
  2. Lifetime 4-Foot Adjustable Table Leg Replacement: paso 2, imagen 1 de 3 Lifetime 4-Foot Adjustable Table Leg Replacement: paso 2, imagen 2 de 3 Lifetime 4-Foot Adjustable Table Leg Replacement: paso 2, imagen 3 de 3
    • Clean any glue or adhesive from the braces and hinges before putting it into place.
    • It’s important to clear the screw holes of any material, so that the screws can fit without obstruction.
  3. Lifetime 4-Foot Adjustable Table Leg Replacement: paso 3, imagen 1 de 3 Lifetime 4-Foot Adjustable Table Leg Replacement: paso 3, imagen 2 de 3 Lifetime 4-Foot Adjustable Table Leg Replacement: paso 3, imagen 3 de 3
    • Align the screw holes of the braces with the new leg by inserting it into the frame.
    • While aligning, make sure the new leg fits into the frame slots.
  4. Lifetime 4-Foot Adjustable Table Leg Replacement: paso 4, imagen 1 de 3 Lifetime 4-Foot Adjustable Table Leg Replacement: paso 4, imagen 2 de 3 Lifetime 4-Foot Adjustable Table Leg Replacement: paso 4, imagen 3 de 3
    • Place the two stainless steel hex screws inside of the screw holes located on the leg, and secure each screw with your Allen key or wrench.
  5. Lifetime 4-Foot Adjustable Table Leg Replacement: paso 5, imagen 1 de 3 Lifetime 4-Foot Adjustable Table Leg Replacement: paso 5, imagen 2 de 3 Lifetime 4-Foot Adjustable Table Leg Replacement: paso 5, imagen 3 de 3
    • Screw the four slotted screws back into the frame using a 6 mm flathead screwdriver. Ensure that the entire side where the new leg is being inserted is securely connected to the table once again.
  6. Lifetime 4-Foot Adjustable Table Leg Replacement: paso 6, imagen 1 de 1
    • Test out the table by unfolding it, and setting it up in a standing position.
    • If the leg is not aligned properly, has loose screws, or missing some screws, make the proper adjustments before using it.
Conclusión
Aphason Aberham
Miembro Desde 09/11/23
133 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 56
Todo El Tiempo: 316
