Saltar al contenido principal
LifePrint 3x4.5 Charging Port Replacement
Qué necesitas
  1. LifePrint 3x4.5 Charging Port Replacement, Top Cover: paso 1, imagen 1 de 1
    • Place one hand on the top cover and one hand on the bottom portion of the LifePrint.
    • While having the LP logo on the printer facing away from you, push the top cover away from you until it can't be slid away any further.
    • Pull the cover with the LP logo up to separate it from the rest of the printer.
  2. LifePrint 3x4.5 Charging Port Replacement, Inner Cover: paso 2, imagen 1 de 1
    • Using a Phillips #0 screwdriver, remove the four 15 mm screws connecting both sections of the device.
    • Use an opening tool to remove the inner cover from the printer.
  3. LifePrint 3x4.5 Charging Port Replacement, Charging Port: paso 3, imagen 1 de 1
    • Remove the five Phillips #0 screws from the outer edge of the motherboard indicated by the copper color surrounding the screws' housing.
  4. LifePrint 3x4.5 Charging Port Replacement: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Use a soldering iron to heat up the soldering joints surrounding the port that connects the device to the circuit board.
    • After the solder is heated up use the de-soldering wick to absorb the solder holding the socket to the circuit board .
    • After the solder is removed use the tweezers to remove the port from the circuit board.
Conclusión
Equipo
UMass Dartmouth, Team S1-G2, Barthe Fall 2019 Miembro de UMass Dartmouth, Team S1-G2, Barthe Fall 2019
UMASSD-BARTHE-F19S1G2
Miembros de 3
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 14
Todo El Tiempo: 425
