Introducción
The Lifeprint 3 x 4.5 uses a rechargeable Lithium ion battery. In the case that the Lifeprint won’t charge, replacing the rechargeable battery is a potential solution to allow your Lifeprint to turn on.
Qué necesitas
Place one hand on the top cover and one hand on the bottom portion of the LifePrint.
While having the LP logo on the printer facing away from you, push the top cover away from you until it can't be slid away any further.
Pull the cover with the LP logo up to separate it from the rest of the printer.
Using a Phillips #0 screwdriver, remove the four 15 mm screws connecting both sections of the device.
Use an opening tool to remove the inner cover from the printer.
Remove three 4mm Phillips #0 screws connecting the metal shield covering the battery.
Slide out the white power connector with two red wires, two black wires, and one yellow wire from the terminal connected to the circuit board.
Apply pressure gently and slowly from underneath the battery from the plastic.
3 comentarios
C'est parfait mais la batterie EVE P0867 7.4V 900mAh est introuvable... Avez vous un lien ?
Merci
