Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Lexus IS Oil and Oil Filter Replacement
Qué necesitas
  1. Lexus IS Oil and Oil Filter Replacement, Lift the car: paso 1, imagen 1 de 2 Lexus IS Oil and Oil Filter Replacement, Lift the car: paso 1, imagen 2 de 2
    • I used home-made wooden car-ramps, but you can use a jack and jack-stands, or store-bought ramps
    Pregunta a FixBot
    Agregar Comentario
  2. Lexus IS Oil and Oil Filter Replacement, Gather your tools: paso 2, imagen 1 de 3 Lexus IS Oil and Oil Filter Replacement, Gather your tools: paso 2, imagen 2 de 3 Lexus IS Oil and Oil Filter Replacement, Gather your tools: paso 2, imagen 3 de 3
    • The tools I used were:
    • 14mm wrench for drain bolt
    • Toyota filter housing wrench
    • 1/2in rachet to drive the filter housing wrench
    • Drain pan and clean/dirty rags
    • Pick or small screwdriver to pull off the old O-ring
    • Philips 3 screwdriver to remove filter housing access panel, can also use 10mm socket
    • Big-mouth funnel
    Pregunta a FixBot
    Agregar Comentario
  3. Lexus IS Oil and Oil Filter Replacement, Remove oil filter housing access panel: paso 3, imagen 1 de 3 Lexus IS Oil and Oil Filter Replacement, Remove oil filter housing access panel: paso 3, imagen 2 de 3 Lexus IS Oil and Oil Filter Replacement, Remove oil filter housing access panel: paso 3, imagen 3 de 3
    • Remove the filter housing access panel with the screwdriver or 10mm socket
    • There are 3 screws
    Pregunta a FixBot
    Agregar Comentario
    • Position your drain pan under the oil pan - it's right-side of engine
    • Remove the oil pan drain bolt and try to avoid the mess!
    Pregunta a FixBot
    Agregar Comentario
  4. Lexus IS Oil and Oil Filter Replacement, Re-install the drain bolt: paso 5, imagen 1 de 3 Lexus IS Oil and Oil Filter Replacement, Re-install the drain bolt: paso 5, imagen 2 de 3 Lexus IS Oil and Oil Filter Replacement, Re-install the drain bolt: paso 5, imagen 3 de 3
    • Once the oil is drained, wipe around the drain hole with your rags
    • Re-install the drain bolt with your 14mm wrench or socket - don't over-tighten it!
    • You're supposed to replace the washer on the bolt every time, but sometimes you forget to buy new ones
    Pregunta a FixBot
    Agregar Comentario
    • Reposition your drain pan under the oil filter housing
    • Loosen the filter housing with your filter-housing-tool, or possibly with large channel-lock pliers...
    • While loosening it will start to drip - reposition your drain pan as required
    • Remove the filter housing completely
    Pregunta a FixBot
    Agregar Comentario
  5. Lexus IS Oil and Oil Filter Replacement, Install new filter and clean filter housing: paso 7, imagen 1 de 3 Lexus IS Oil and Oil Filter Replacement, Install new filter and clean filter housing: paso 7, imagen 2 de 3 Lexus IS Oil and Oil Filter Replacement, Install new filter and clean filter housing: paso 7, imagen 3 de 3
    • Remove the old filter from the housing
    • Clean out the housing as required
    • It's usually at this point I switch to the next cleaner level of rag
    • Remove the housing o-ring with a small screwdriver or pick - there is actually a cut-out in the lip to allow easy access - Thanks Toyota
    • Wipe some oil on your new O-ring and ensure it's in the correct groove in the housing
    Pregunta a FixBot
    Agregar Comentario
  6. Lexus IS Oil and Oil Filter Replacement, Re-install filter housing and cover: paso 8, imagen 1 de 3 Lexus IS Oil and Oil Filter Replacement, Re-install filter housing and cover: paso 8, imagen 2 de 3 Lexus IS Oil and Oil Filter Replacement, Re-install filter housing and cover: paso 8, imagen 3 de 3
    • After preparing the filter housing with new filter and o-ring, screw it back into the opening
    • It does not need to be super-tight, it seals with the o-ring, just snug it up
    • Re-install the cover using your 3 screws from before, I recommend only using a screwdriver, since you want to barely torque these - they go into plastic
    Pregunta a FixBot
    Agregar Comentario
  7. Lexus IS Oil and Oil Filter Replacement, Re-fill the engine with oil: paso 9, imagen 1 de 3 Lexus IS Oil and Oil Filter Replacement, Re-fill the engine with oil: paso 9, imagen 2 de 3 Lexus IS Oil and Oil Filter Replacement, Re-fill the engine with oil: paso 9, imagen 3 de 3
    • Now it's time to go up-top and re-fill the engine with Oil
    • I used Penrite HPR 5
    • My 2008 Lexus IS350 took around 6.6L of oil to fill
    • After I put in around 6L I took it down off the ramps to level the car before taking the final readings on the dipstick
    • The dipstick is on the right-side of the engine on IS350
    • The dipstick will only read correctly when the car is on level ground
    • Now you get to clean up the mess with your remaining rags or kitty litter or whatever.
    • Usually I start up the engine and run it for around 5 seconds (while listening intently) then check under for leaks
    Pregunta a FixBot
    Agregar Comentario
  8. Lexus IS Oil and Oil Filter Replacement, Final tool detail: paso 10, imagen 1 de 3 Lexus IS Oil and Oil Filter Replacement, Final tool detail: paso 10, imagen 2 de 3 Lexus IS Oil and Oil Filter Replacement, Final tool detail: paso 10, imagen 3 de 3
    • Maybe you have questions about the filter housing tool?
    • It's a Moker, I got it from Amazon https://www.amazon.com/Moker-Compatible-...
    • I'm in New Zealand, so the car is a JDM import from Japan, and I'm using locally-purchased Australian Penrite HPR 5 oil, and a Japanese JS Asakashi OE116J filter bought online from Singapore
    Pregunta a FixBot
    Agregar Comentario
Conclusión
After starting the car check underneath for any leaks.
Gaspard Leon
Miembro Desde 04/24/10
2,855 Reputación
8 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 24
Ultimos 30 días: 136
Todo El Tiempo: 5,777
