Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Lexus IS 350 Engine Air Filter Replacement
Qué necesitas
  1. Lexus IS 350 Engine Air Filter Replacement, Engine Air Filter: paso 1, imagen 1 de 2 Lexus IS 350 Engine Air Filter Replacement, Engine Air Filter: paso 1, imagen 2 de 2
    • Pull the hood latch located under the dashboard on the driver’s side to release the hood.
    • Raise the car's hood until the hood struts engage and hold it in the open position.
    Pregunta a FixBot
    Agregar Comentario
  2. Lexus IS 350 Engine Air Filter Replacement: paso 2, imagen 1 de 1
    • Locate the engine air filter box, positioned in front and to the side of the engine.
    Pregunta a FixBot
    Agregar Comentario
  3. Lexus IS 350 Engine Air Filter Replacement: paso 3, imagen 1 de 3 Lexus IS 350 Engine Air Filter Replacement: paso 3, imagen 2 de 3 Lexus IS 350 Engine Air Filter Replacement: paso 3, imagen 3 de 3
    • Squeeze the three clips securing the air filter box cover to release them from the cover.
    • Ensure the clips are fully released to avoid damaging them.
    • Remember the orientation of the clips for reassembly.
    Pregunta a FixBot
    Agregar Comentario
  4. Lexus IS 350 Engine Air Filter Replacement: paso 4, imagen 1 de 3 Lexus IS 350 Engine Air Filter Replacement: paso 4, imagen 2 de 3 Lexus IS 350 Engine Air Filter Replacement: paso 4, imagen 3 de 3
    • Lift the cover and remove the engine air filter.
    Pregunta a FixBot
    Agregar Comentario
  5. Lexus IS 350 Engine Air Filter Replacement: paso 5, imagen 1 de 3 Lexus IS 350 Engine Air Filter Replacement: paso 5, imagen 2 de 3 Lexus IS 350 Engine Air Filter Replacement: paso 5, imagen 3 de 3
    • Place the new air filter inside the air filter box.
    • Close the engine air filter box lid and secure the clips.
    Pregunta a FixBot
    Agregar Comentario
  6. Lexus IS 350 Engine Air Filter Replacement: paso 6, imagen 1 de 1
    • Close the hood of the car by carefully lowering it and ensuring it is latched properly.
    • Start your car and ensure it runs smoothly. Check for any unusual noises or issues.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
You have successfully changed your engine air filter for your Lexus IS350/250!
2 personas más completaron esta guía.
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 15
Ultimos 30 días: 62
Todo El Tiempo: 1,107
