Saltar al contenido principal
Lexmark Intuition S505 Ink Cartridges Replacement
  1. Lexmark Intuition S505 Ink Cartridges Replacement, Ink Cartridges: paso 1, imagen 1 de 2 Lexmark Intuition S505 Ink Cartridges Replacement, Ink Cartridges: paso 1, imagen 2 de 2
    • Lift the scanning unit, exposing the print head.
  2. Lexmark Intuition S505 Ink Cartridges Replacement: paso 2, imagen 1 de 1
    • Locate the frame around the ink cartridges. Press the button located at the front of the cartridge frame.
  3. Lexmark Intuition S505 Ink Cartridges Replacement: paso 3, imagen 1 de 1
    • Lift the frame to expose the ink cartridges.
  4. Lexmark Intuition S505 Ink Cartridges Replacement: paso 4, imagen 1 de 1
    • Push the button located above the designated ink cartridge until it pops out.
  5. Lexmark Intuition S505 Ink Cartridges Replacement: paso 5, imagen 1 de 1
    • Pull the cartridge out, and place the new ink cartridge back into the slot. Push until you hear a click.
  6. Lexmark Intuition S505 Ink Cartridges Replacement: paso 6, imagen 1 de 2 Lexmark Intuition S505 Ink Cartridges Replacement: paso 6, imagen 2 de 2
    • Close the scanner unit.
Conclusión
Once your ink cartridges are in place, your printer should now print high-quality documents.
2 personas más completaron esta guía.
Omar
Miembro Desde 01/23/13
111 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 18-38, Regan Winter 2013 Miembro de Cal Poly, Team 18-38, Regan Winter 2013
CPSU-REGAN-W13S18G38
4 Miembros
8 Guías creadas
Un comentario
Hello there, thanks for your demonstration. In case that the cartridges are not genuine (not a lexmark brand), will the printer will be able to print?
I own this model. Thanks in advance!
Dimitri Sideris - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 3,270
