Introducción
The adapter connects the power chord to the printer.
Locate adapter and observe that the two contacts, marked by the red rectangle, of the adapter are facing up.
  • Locate adapter and observe that the two contacts, marked by the red rectangle, of the adapter are facing up.
Agregar Comentario
Insert adapter into the bottom-right slot behind the printer with the adapter end facing outward.
  • Insert adapter into the bottom-right slot behind the printer with the adapter end facing outward.
Agregar Comentario
  • Firmly push adapter in until you hear a click.
Agregar Comentario
Conclusión
The adapter should be securely inserted into the back end of the printer and be ready for use.
Una persona más ha completado esta guía.
Raymond
Miembro Desde 15/01/13
42 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 18-38, Regan Winter 2013 Miembro de Cal Poly, Team 18-38, Regan Winter 2013
CPSU-REGAN-W13S18G38
4 Miembros
9 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 8
Todo El Tiempo: 690
