Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
This guide replaces the motherboard, which houses the majority of the components for the Lexibook Junior tablet. This guide requires the removal of the battery first.
  1. Make sure your device is powered off before replacement to prevent electric shock.
    • Make sure your device is powered off before replacement to prevent electric shock.
    • With the device screen face down, use the metal spudger to remove the small rubber circles on all four corners of the device. The screws should now be revealed.
    • Using the metal spudger, pry open the small, long rubber rectangle on the back of the device to reveal more screws.
  2. Using a Phillips #00 screwdriver, remove the four 6.8mm screws from the four corners of the device.
    • Using a Phillips #00 screwdriver, remove the four 6.8mm screws from the four corners of the device.
    • Using the same screwdriver, remove the three screws that were behind the rubber rectangle. These screws do not come out of the device.
    • Use the plastic opening tool to gently pry open the back panel of the tablet.
  3. Use the nylon spudger to gently pry under the battery to remove it.
    • Use the nylon spudger to gently pry under the battery to remove it.
    • Make sure you do not damage the battery or metal plate in this process and only use a nylon spudger. Be patient and work slowly for the best results.
  4. Use a soldering iron to remove the battery from the motherboard safely.
    • Use a soldering iron to remove the battery from the motherboard safely.
    • For advice on how to solder, check out iFixit's Soldering Guide.
  5. Using the plastic opening tool, gently push the two small, black and white switches out in the direction of the ribbon wires. Slowly pull the ribbon wire out of the switch to free it.
    • Using the plastic opening tool, gently push the two small, black and white switches out in the direction of the ribbon wires.
    • Slowly pull the ribbon wire out of the switch to free it.
  6. Push the larger black and white strip leading to a ribbon wire upward using the plastic opening tool.
    • Push the larger black and white strip leading to a ribbon wire upward using the plastic opening tool.
    • Carefully pull the ribbon wire out of the switch
  7. Unscrew the five 4 mm  screws around the perimeter of the motherboard using the ph00 size phillips head screwdriver. Unscrew the five 4 mm  screws around the perimeter of the motherboard using the ph00 size phillips head screwdriver. Unscrew the five 4 mm  screws around the perimeter of the motherboard using the ph00 size phillips head screwdriver.
    • Unscrew the five 4 mm screws around the perimeter of the motherboard using the ph00 size phillips head screwdriver.
  8. Remove the button board by unscrewing two more 4 mm screws and one 6.5 mm screw Remove the button board by unscrewing two more 4 mm screws and one 6.5 mm screw
    • Remove the button board by unscrewing two more 4 mm screws and one 6.5 mm screw
  9. Solder off connections from the wire connecting the motherboard to the speaker.
    • Solder off connections from the wire connecting the motherboard to the speaker.
    • For how to solder, check out iFixit's Soldering Guide.
Conclusión
Rachel Klesius
Miembro Desde 19/09/16
645 Reputación
6 Guías creadas
Equipo
USF Tampa, Team 17-3, Blackwell Fall 2016 Miembro de USF Tampa, Team 17-3, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G3
4 Miembros
12 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 201
