Introducción
This guide requires soldering skills and the removal of both the battery and the motherboard. This is one of the harder guides.
Qué necesitas
With the device screen face down, use the metal spudger to remove the small rubber circles on all four corners of the device. The screws should now be revealed.
Using the metal spudger, pry open the small, long rubber rectangle on the back of the device to reveal more screws.
Using a Phillips #00 screwdriver, remove the four 6.8mm screws from the four corners of the device.
Using the same screwdriver, remove the three screws that were behind the rubber rectangle. These screws do not come out of the device.
Use the plastic opening tool to gently pry open the back panel of the tablet.
Using the plastic opening tool, gently push the two small, black and white switches out in the direction of the ribbon wires.
Slowly pull the ribbon wire out of the switch to free it.
