Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
This is one of the easiest parts of the Lexibook Junior Tablet to replace. This repair might be needed if all other attempts to restore power fail. You would need to replace this in the case that your Lexibook Junior Tablet is older because the battery might go bad with use.
  1. Make sure your device is powered off before replacement to prevent electric shock.
    • Make sure your device is powered off before replacement to prevent electric shock.
    • With the device screen face down, use the metal spudger to remove the small rubber circles on all four corners of the device. The screws should now be revealed.
    • Using the metal spudger, pry open the small, long rubber rectangle on the back of the device to reveal more screws.
  2. Using a Phillips #00 screwdriver, remove the four 6.8mm screws from the four corners of the device.
    • Using a Phillips #00 screwdriver, remove the four 6.8mm screws from the four corners of the device.
    • Using the same screwdriver, remove the three screws that were behind the rubber rectangle. These screws do not come out of the device.
    • Use the plastic opening tool to gently pry open the back panel of the tablet.
  3. Use the nylon spudger to gently pry under the battery to remove it.
    • Use the nylon spudger to gently pry under the battery to remove it.
    • Make sure you do not damage the battery or metal plate in this process and only use a nylon spudger. Be patient and work slowly for the best results.
  4. Use a soldering iron to remove the battery from the motherboard safely.
    • Use a soldering iron to remove the battery from the motherboard safely.
    • For advice on how to solder, check out iFixit's Soldering Guide.
Conclusión
Una persona más ha completado esta guía.
Rachel Klesius
Miembro Desde 19/09/16
645 Reputación
6 Guías creadas
Equipo
USF Tampa, Team 17-3, Blackwell Fall 2016 Miembro de USF Tampa, Team 17-3, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G3
4 Miembros
12 Guías creadas
Bonjour avez vous lien pour l'achat de la batterie en question. Merci
Akrame Chakir - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 21
Todo El Tiempo: 733
