Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Les Paul Wireless Guitar Strummer Replacement
Qué necesitas
  1. Les Paul Wireless Guitar Strummer Replacement, Les Paul Wireless Guitar Body Teardown: paso 1, imagen 1 de 1
    • Remove batteries
    Pregunta a FixBot
    Agregar Comentario
  2. Les Paul Wireless Guitar Strummer Replacement: paso 2, imagen 1 de 2 Les Paul Wireless Guitar Strummer Replacement: paso 2, imagen 2 de 2
    • Remove void warranty sticker
    • The sticker is covering a torx screw
    Pregunta a FixBot
    Agregar Comentario
  3. Les Paul Wireless Guitar Strummer Replacement: paso 3, imagen 1 de 3 Les Paul Wireless Guitar Strummer Replacement: paso 3, imagen 2 de 3 Les Paul Wireless Guitar Strummer Replacement: paso 3, imagen 3 de 3
    • Unscrew the 11 screws securing the back of the body using a T10 Torx screwdriver. Each screw is 1 cm long.
    • Push level, this will detach the back of the guitar from the front.
    • Carefully remove the back of the body
    • The battery pack cord is attached to both sides of the guitar, be careful not to tear it apart.
    • The neck connector may be stuck to the back so be sure to detach it before fully pulling
    Pregunta a FixBot
    Agregar Comentario
  4. Les Paul Wireless Guitar Strummer Replacement, Strummer: paso 4, imagen 1 de 2 Les Paul Wireless Guitar Strummer Replacement, Strummer: paso 4, imagen 2 de 2
    • Remove the 4 screws from the back of the strum chip using a Phillips PH1 screwdriver. each of these screws are 1.2 cm each.
    • Remove the 4 inner screws, each are 0.8 cm.
    • Make sure that when putting back together, the 4 inner screws line up with the small plastic piece underneath.
    Pregunta a FixBot
    Agregar Comentario
  5. Les Paul Wireless Guitar Strummer Replacement: paso 5, imagen 1 de 3 Les Paul Wireless Guitar Strummer Replacement: paso 5, imagen 2 de 3 Les Paul Wireless Guitar Strummer Replacement: paso 5, imagen 3 de 3
    • Remove the two plastic holders on the underside of the chip.
    • Pull out the the plastic piece on each side of the strummer.
    • Lift the strummer out of it's location
    Pregunta a FixBot
    Agregar Comentario
  6. Les Paul Wireless Guitar Strummer Replacement: paso 6, imagen 1 de 3 Les Paul Wireless Guitar Strummer Replacement: paso 6, imagen 2 de 3 Les Paul Wireless Guitar Strummer Replacement: paso 6, imagen 3 de 3
    • Take the top black cover off the strummer.
    • Slide the black rod out of the side.
    • Clean if needed.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
4 personas más completaron esta guía.
Chris
Miembro Desde 10/18/13
922 Reputación
6 Guías creadas
4Guía Comentarios
Hi recently bought this controller again and the up strum has stopped functioning. Hoping this will fix it. Thanks
liamiley91 - Contestar Compartir
Did this fix your issue? Thinking about trying it.
D. Preston Peek - Contestar Compartir
Same here, i want to it try but want to know if i will be able to do it altough i’m not really good with these kind of work
Sébastien Fortuny - Contestar Compartir
This guitar don't have star power with up guitar? Where is sensor?
Leandro Loureiro - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 18
Ultimos 30 días: 101
Todo El Tiempo: 22,315
