Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Les Paul Wireless Guitar Peripheral Neck Connection Replacement
Qué necesitas
  1. Les Paul Wireless Guitar Peripheral Neck Connection Replacement, Les Paul Wireless Guitar Body Teardown: paso 1, imagen 1 de 1
    • Remove batteries
  2. Les Paul Wireless Guitar Peripheral Neck Connection Replacement: paso 2, imagen 1 de 2 Les Paul Wireless Guitar Peripheral Neck Connection Replacement: paso 2, imagen 2 de 2
    • Remove void warranty sticker
    • The sticker is covering a torx screw
  3. Les Paul Wireless Guitar Peripheral Neck Connection Replacement: paso 3, imagen 1 de 3 Les Paul Wireless Guitar Peripheral Neck Connection Replacement: paso 3, imagen 2 de 3 Les Paul Wireless Guitar Peripheral Neck Connection Replacement: paso 3, imagen 3 de 3
    • Unscrew the 11 screws securing the back of the body using a T10 Torx screwdriver. Each screw is 1 cm long.
    • Push level, this will detach the back of the guitar from the front.
    • Carefully remove the back of the body
    • The battery pack cord is attached to both sides of the guitar, be careful not to tear it apart.
    • The neck connector may be stuck to the back so be sure to detach it before fully pulling
  4. Les Paul Wireless Guitar Peripheral Neck Connection Replacement, Neck Connection: paso 4, imagen 1 de 2 Les Paul Wireless Guitar Peripheral Neck Connection Replacement, Neck Connection: paso 4, imagen 2 de 2
    • Remove the 10 screws (each are 1 cm long) on the back of the neck using a T-10 Torx security screwdriver.
    • Remove the back of the neck.
  5. Les Paul Wireless Guitar Peripheral Neck Connection Replacement: paso 5, imagen 1 de 2 Les Paul Wireless Guitar Peripheral Neck Connection Replacement: paso 5, imagen 2 de 2
    • First check to see if the button motherboard is not damaged.
    • Next, make sure the wire is not damaged.
    • Then make sure that the connection motherboard is also not damaged.
    • If any of these parts are damaged, then it will need to be replaced.
  6. Les Paul Wireless Guitar Peripheral Neck Connection Replacement: paso 6, imagen 1 de 1
    • Check to see if the neck connection chip is not damaged inside of the guitar.
    • Make sure that all 8 prongs of the chip are not damaged or broken.
    • If the neck chip is damaged then it will need to be replaced.
  7. Les Paul Wireless Guitar Peripheral Neck Connection Replacement: paso 7, imagen 1 de 3 Les Paul Wireless Guitar Peripheral Neck Connection Replacement: paso 7, imagen 2 de 3 Les Paul Wireless Guitar Peripheral Neck Connection Replacement: paso 7, imagen 3 de 3
    • The lock mechanism may be another reason for trouble in your neck connection.
    • Use the guitar tear down to open the guitar to this point.
    • Start by unscrewing the two screws holding down the main connection parts. The first screw is 1 cm and the second screw is 0.8 cm.
  8. Les Paul Wireless Guitar Peripheral Neck Connection Replacement: paso 8, imagen 1 de 1
    • Take the spring off the main connection mechanism. It should come off pretty easily.
    • If this spring is broken or snapped, then it will need to be replaced.
  9. Les Paul Wireless Guitar Peripheral Neck Connection Replacement: paso 9, imagen 1 de 2 Les Paul Wireless Guitar Peripheral Neck Connection Replacement: paso 9, imagen 2 de 2
    • Pull out the main connection mechanism.
    • Make sure that it is not broken or it will need to be replaced.
    • This can be put back together by inserting the mechanism again, attaching the spring and screwing the two screws back in place.
Conclusión
3 personas más completaron esta guía.
Chris
Miembro Desde 10/18/13
922 Reputación
6 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 26
Ultimos 30 días: 124
Todo El Tiempo: 13,664
