Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Les Paul Wireless Guitar Peripheral Fret Buttons Replacement
Qué necesitas
    1. Les Paul Wireless Guitar Peripheral Fret Buttons Replacement, Fret Buttons: paso 1, imagen 1 de 1
      • Pull the Lock on the back of the body to detach the neck from the body.
      Pregunta a FixBot
      Agregar Comentario
    2. Les Paul Wireless Guitar Peripheral Fret Buttons Replacement: paso 2, imagen 1 de 2 Les Paul Wireless Guitar Peripheral Fret Buttons Replacement: paso 2, imagen 2 de 2
      • Remove the 10 screws (each are 1 cm long) on the back of the neck using a T-10 Torx security screwdriver.
      • Remove the back of the neck.
      Pregunta a FixBot
      Agregar Comentario
    3. Les Paul Wireless Guitar Peripheral Fret Buttons Replacement: paso 3, imagen 1 de 2 Les Paul Wireless Guitar Peripheral Fret Buttons Replacement: paso 3, imagen 2 de 2
      • Unscrew the two screws on the fret PCB using a PH1 Phillips head screwdriver. Each screw is 0.8 cm.
      • Remove the fret PCB
      • The fret PCB is in very tight. Be careful not to break it.
      • The connector from the neck to the body can easily slide out of place. Make sure it is in position before closing the neck
      Pregunta a FixBot
      Agregar Comentario
    4. Les Paul Wireless Guitar Peripheral Fret Buttons Replacement: paso 4, imagen 1 de 1
      • Remove the blue fret button pad.
      • This pad should not be attached in any way
      Pregunta a FixBot
      Agregar Comentario
    5. Les Paul Wireless Guitar Peripheral Fret Buttons Replacement: paso 5, imagen 1 de 2 Les Paul Wireless Guitar Peripheral Fret Buttons Replacement: paso 5, imagen 2 de 2
      • The fret buttons should now easily slide out.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
7 personas más completaron esta guía.
Chris
Miembro Desde 10/18/13
922 Reputación
6 Guías creadas
1Guía Comentario
There are actually 12 screws in Step2. Just in case anyone is confused by that; starting from the right side we have a pair lined horizontally, pair lined vertically, pair lined horizontally....
The two that are vertically between the other two pairs, are not marked in the photo.
Vynneve - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 24
Ultimos 30 días: 100
Todo El Tiempo: 22,848
