Introducción
This guide will show how to replace the guitar's battery pack. The battery pack supplies power to the controller and houses the two AA batteries required for the controller.
Herramientas
No se requieren herramientas.
Partes
No se requieren partes.
  1. Remove batteries
    • Remove batteries
  2. Remove void warranty sticker The sticker is covering a torx screw
    • Remove void warranty sticker
      • The sticker is covering a torx screw
  3. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Unscrew the 11 screws securing the back of the body using a T10 Torx screwdriver. Each screw is 1 cm long. Push level, this will detach the back of the guitar from the front. Carefully remove the back of the body
    • Unscrew the 11 screws securing the back of the body using a T10 Torx screwdriver. Each screw is 1 cm long.
    • Push level, this will detach the back of the guitar from the front.
    • Carefully remove the back of the body
      • The battery pack cord is attached to both sides of the guitar, be careful not to tear it apart.
      • The neck connector may be stuck to the back so be sure to detach it before fully pulling
  5. Gently move the capacitor around until it breaks off Gently move the capacitor around until it breaks off
    • Gently move the capacitor around until it breaks off
  6. Solder on the new capacitor.
    • Solder on the new capacitor.
Conclusión
Una persona más ha completado esta guía.
Chris
Miembro Desde 18/10/13
752 Reputación
6 Guías creadas
Yo can you help for the drum set I saw two wires detached ( red an black) when I I opened it up. Please email me so I can send a picture djcab361@outlook.com
Chris - Contestar
Ver Estadísticas:
Ultimas 24 Horas: 5
Últimos 7 Días: 20
Últimos 30 Días: 82
Todo El Tiempo: 4,669
