Introducción
Your axe isn't sounding right or just isn’t working but you don't want to spend a lot to fix it? This will let you change out your pickups in no time, without damaging your wallet in the process. Have a new set of pickups ready and you can jump right in. This guide will walk you through the process of changing the pickups on your Les Paul guitar.
Qué necesitas
Loosen the guitar strings using a string winder.
Using a coin, carefully begin unscrewing and removing the tailpiece.
Remove the tailpiece by completely unscrewing it from the metal inserts and then gently lifting the assembly out of the body and set off to the side.
Plug in your beloved guitar and rock out with your fresh pickups
2 personas más completaron esta guía.
