Saltar al contenido principal
Lens Replacement
Qué necesitas
  1. Lens Replacement, Lens: paso 1, imagen 1 de 3 Lens Replacement, Lens: paso 1, imagen 2 de 3 Lens Replacement, Lens: paso 1, imagen 3 de 3
    • Step 1. Remove: Remove the indicated screws from the camera.
  2. Lens Replacement: paso 2, imagen 1 de 3 Lens Replacement: paso 2, imagen 2 de 3 Lens Replacement: paso 2, imagen 3 de 3
    • Step 2. Remove all the screws: Keep all the screws and disconnect the cables carefully.
    • Step 3. Lift: After removing all the cables, lift up and flip over the PCB.
  3. Lens Replacement: paso 3, imagen 1 de 2 Lens Replacement: paso 3, imagen 2 de 2
    • Step 4. Remove: Remove marked screws on top and around the lent.
    • **Remove all the parts, be aware that there are a lot of screws and keep count them a long the way of the dissambley **
  4. Lens Replacement: paso 4, imagen 1 de 2 Lens Replacement: paso 4, imagen 2 de 2
    • Step 5. Carefully remove as much of the glue as possible before proceeding to the next step.
    • Step 6. Remove the marked focus spacers.
    • Place a bead of silicone adhesive on each side of the ir filter to fix it in position and allow to cure.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 16
Todo El Tiempo: 1,307
