Saltar al contenido principal
Lenovo bluetooth mouse N6901A disassembly
Qué necesitas
  1. Lenovo bluetooth mouse N6901A disassembly, Mouse: paso 1, imagen 1 de 1
    • 3 Phillips screws are located under the battery cover, unscrew them
  2. Lenovo bluetooth mouse N6901A disassembly: paso 2, imagen 1 de 2 Lenovo bluetooth mouse N6901A disassembly: paso 2, imagen 2 de 2
    • The mouse cover at the bottom should move freely but at the top is hold by 2 brackets
    • In order to remove the mouse cover, you will need to rock left/right the cover and slide it down (from scroll wheel toward the Lenovo logo)
  3. Lenovo bluetooth mouse N6901A disassembly: paso 3, imagen 1 de 2 Lenovo bluetooth mouse N6901A disassembly: paso 3, imagen 2 de 2
    • At this point, you have separated the mouse cover
  4. Lenovo bluetooth mouse N6901A disassembly: paso 4, imagen 1 de 1
    • Use the appropriate tool to remove gently the power connector. Don't use your finger, you might brake the cable
  5. Lenovo bluetooth mouse N6901A disassembly: paso 5, imagen 1 de 2 Lenovo bluetooth mouse N6901A disassembly: paso 5, imagen 2 de 2
    • The micro switch can be replaced by OMRON D2FC-F-7N but you need to trim the solder terminals with a flush wire cutter
    • When you reassemble the mouse, make sure you don't crush the power cable
Conclusión
Una persona más ha completado esta guía.
Shinn Chyang Chen
Miembro Desde 09/14/11
2,923 Reputación
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 44
Todo El Tiempo: 5,512
