Saltar al contenido principal
Partes
No se especificaron partes.
  1. 3 Phillips screws are located under the battery cover, unscrew them
    • 3 Phillips screws are located under the battery cover, unscrew them
  2. The mouse cover at the bottom should move freely but at the top is hold by 2 brackets In order to remove the mouse cover, you will need to rock left/right the cover and slide it down (from scroll wheel toward the Lenovo logo)
    • The mouse cover at the bottom should move freely but at the top is hold by 2 brackets
    • In order to remove the mouse cover, you will need to rock left/right the cover and slide it down (from scroll wheel toward the Lenovo logo)
  3. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  4. At this point, you have separated the mouse cover At this point, you have separated the mouse cover
    • At this point, you have separated the mouse cover
  5. Use the appropriate tool to remove gently the power connector. Don't use your finger, you might brake the cable
    • Use the appropriate tool to remove gently the power connector. Don't use your finger, you might brake the cable
  6. The micro switch can be replaced by OMRON D2FC-F-7N but you need to trim the solder terminals with a flush wire cutter When you reassemble the mouse, make sure you don't crush the power cable
    • The micro switch can be replaced by OMRON D2FC-F-7N but you need to trim the solder terminals with a flush wire cutter
    • When you reassemble the mouse, make sure you don't crush the power cable
Conclusión
Una persona más ha completado esta guía.
Shinn Chyang Chen
Miembro Desde 14/09/11
2,212 Reputación
3 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 8
Últimos 30 Días: 33
Todo El Tiempo: 2,957
