Saltar al contenido principal
Lenovo Z70-80 Motherboard Replacement
Qué necesitas
  1. Lenovo Z70-80 Motherboard Replacement, Battery: paso 1, imagen 1 de 2 Lenovo Z70-80 Motherboard Replacement, Battery: paso 1, imagen 2 de 2
    • Use your fingers two push both latches away from each other to release the battery.
    • Pull the battery out.
  2. Lenovo Z70-80 Motherboard Replacement, Back Panel: paso 2, imagen 1 de 3 Lenovo Z70-80 Motherboard Replacement, Back Panel: paso 2, imagen 2 de 3 Lenovo Z70-80 Motherboard Replacement, Back Panel: paso 2, imagen 3 de 3
    • Remove the two Phillips #0 screws from the bottom panel.
    • Slide the panel down slightly, and then lift to pull it off.
  3. Lenovo Z70-80 Motherboard Replacement, Optical Drive: paso 3, imagen 1 de 3 Lenovo Z70-80 Motherboard Replacement, Optical Drive: paso 3, imagen 2 de 3 Lenovo Z70-80 Motherboard Replacement, Optical Drive: paso 3, imagen 3 de 3
    • Remove the single 3mm Phillips #0 screw from the optical drive.
    • Pull the optical drive out of the side.
  4. Lenovo Z70-80 Motherboard Replacement, Electric Fan: paso 4, imagen 1 de 3 Lenovo Z70-80 Motherboard Replacement, Electric Fan: paso 4, imagen 2 de 3 Lenovo Z70-80 Motherboard Replacement, Electric Fan: paso 4, imagen 3 de 3
    • Remove the three 6mm Phillips #0 screws from the fan.
    • Disconnect the fan from the motherboard by pulling up on the plug.
  5. Lenovo Z70-80 Motherboard Replacement, Motherboard: paso 5, imagen 1 de 1
    • Remove all the 17 7mm Phillips #0 screws.
    • A sticker covers this screw. Remove this sticker to remove the screw.
    • Remove the back cover.
  6. Lenovo Z70-80 Motherboard Replacement: paso 6, imagen 1 de 3 Lenovo Z70-80 Motherboard Replacement: paso 6, imagen 2 de 3 Lenovo Z70-80 Motherboard Replacement: paso 6, imagen 3 de 3
    • Pry the edges of the keyboard upwards using a spudger.
    • A cable with a ZIF connector is attached to the bottom of the keyboard. Flip the small black tab on the connector for safe removal.
    • Remove the five 3mm Phillips #0 screws.
  7. Lenovo Z70-80 Motherboard Replacement: paso 7, imagen 1 de 3 Lenovo Z70-80 Motherboard Replacement: paso 7, imagen 2 de 3 Lenovo Z70-80 Motherboard Replacement: paso 7, imagen 3 de 3
    • Remove all the ribbon cables and connectors from the front and back of the laptop.
    • Remember to flip the small black tabs on ZIF connectors for safe removal.
  8. Lenovo Z70-80 Motherboard Replacement: paso 8, imagen 1 de 2 Lenovo Z70-80 Motherboard Replacement: paso 8, imagen 2 de 2
    • Remove the 3mm screw and carefully pull out the cables from the hooks holding them in place.
  9. Lenovo Z70-80 Motherboard Replacement: paso 9, imagen 1 de 2 Lenovo Z70-80 Motherboard Replacement: paso 9, imagen 2 de 2
    • Use a spudger at the edges of the laptop cover to carefully pry upwards, removing the cover.
  10. Lenovo Z70-80 Motherboard Replacement: paso 10, imagen 1 de 3 Lenovo Z70-80 Motherboard Replacement: paso 10, imagen 2 de 3 Lenovo Z70-80 Motherboard Replacement: paso 10, imagen 3 de 3
    • Unplug the two black cables from the motherboard.
    • Remove the three 3mm screws from the motherboard.
    • Remove the motherboard.
    • Pick up the motherboard carefully by the edges.
Conclusión
3 personas más completaron esta guía.
Documentos Adjuntos
Eduardo Delgado
Miembro Desde 01/24/18
412 Reputación
4 Guías creadas
Equipo
Gateway, Team S1-G4, Johnson Spring 2018 Miembro de Gateway, Team S1-G4, Johnson Spring 2018
GCC-JOHNSON-S18S1G4
2 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 8
Ultimos 30 días: 46
Todo El Tiempo: 4,134
