Introducción
This guide will explain how to remove the back panel on a Lenovo Z70-80 laptop.
Qué necesitas
Use your fingers two push both latches away from each other to release the battery.
Pull the battery out.
Remove the two Phillips #0 screws from the bottom panel.
Slide the panel down slightly, and then lift to pull it off.
Una persona más ha completado esta guía.
