Saltar al contenido principal
Lenovo Yoga Tablet 2 830-F Motherboard Replacement
Qué necesitas
  1. Lenovo Yoga Tablet 2 830-F Motherboard Replacement, Motherboard: paso 1, imagen 1 de 2 Lenovo Yoga Tablet 2 830-F Motherboard Replacement, Motherboard: paso 1, imagen 2 de 2
    • Remove the two 3mm screws on the back of the device with the Phillips Screwdriver #00 bit.
    • Remove the 2mm screw on the back fo the device with a Phillips #00 bit.
    • Using the blue opening tools or spudger, gently remove the back cover to expose the interior of the tablet.
  2. Lenovo Yoga Tablet 2 830-F Motherboard Replacement: paso 2, imagen 1 de 2 Lenovo Yoga Tablet 2 830-F Motherboard Replacement: paso 2, imagen 2 de 2
    • Remove the six 3mm screws on the back of the motherboard with the Phillips Screwdriver #00 bit.
    • Remove the ribbon cables connecting the boards to the other electrical components
    • Remove ZIF connectors connecting the boards to the electrical components.
    • Some of the ribbon cables are secured with clips, simply pry up the clips before sliding them out of the pin connectors.
  3. Lenovo Yoga Tablet 2 830-F Motherboard Replacement: paso 3, imagen 1 de 2 Lenovo Yoga Tablet 2 830-F Motherboard Replacement: paso 3, imagen 2 de 2
    • Replace the motherboard with the new motherboard.
    • Be careful not to damage the ribbon cables when reassembling the device.
Conclusión
Charles Rhode
Miembro Desde 09/28/17
588 Reputación
3 Guías creadas
Equipo
USF Tampa, Team S2-G4, Nance Fall 2017 Miembro de USF Tampa, Team S2-G4, Nance Fall 2017
USFT-NANCE-F17S2G4
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 16
Todo El Tiempo: 1,950
