Saltar al contenido principal
Lenovo Yoga Tablet 2 830-F Camera Replacement
Qué necesitas
  1. Lenovo Yoga Tablet 2 830-F Camera Replacement, Camera: paso 1, imagen 1 de 2 Lenovo Yoga Tablet 2 830-F Camera Replacement, Camera: paso 1, imagen 2 de 2
    • Remove the three screws on the back of the device with the Phillips Screwdriver #00 bit.
    • Using the blue opening tools or spudger, gently remove the back cover to expose the interior of the tablet.
  2. Lenovo Yoga Tablet 2 830-F Camera Replacement: paso 2, imagen 1 de 3 Lenovo Yoga Tablet 2 830-F Camera Replacement: paso 2, imagen 2 de 3 Lenovo Yoga Tablet 2 830-F Camera Replacement: paso 2, imagen 3 de 3
    • Using the Phillips Screwdriver #00 bit remove the 6 screws.
    • Using the Phillips Screwdriver #00 bit remove the 3 screws.
    • After removing all the screws, disconnect the ribbon cables.
    • Disconnect the ZIF connectors.
    • Some of the ribbon cables are secured with clips, simply pry up the clips before sliding them out of the pin connectors.
  3. Lenovo Yoga Tablet 2 830-F Camera Replacement: paso 3, imagen 1 de 3 Lenovo Yoga Tablet 2 830-F Camera Replacement: paso 3, imagen 2 de 3 Lenovo Yoga Tablet 2 830-F Camera Replacement: paso 3, imagen 3 de 3
    • After removing the motherboard and antennas the camera module is located on the right as marked in red.
    • Remove the three 2mm screws holding the module in place with the Phillips Screwdriver #00 bit.
    • The camera module is also held in place with adhesive so gently remove.
Conclusión
Una persona más ha completado esta guía.
Mario Gjyli
Miembro Desde 09/28/17
449 Reputación
3 Guías creadas
Equipo
USF Tampa, Team S2-G4, Nance Fall 2017 Miembro de USF Tampa, Team S2-G4, Nance Fall 2017
USFT-NANCE-F17S2G4
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 12
Todo El Tiempo: 683
