Introducción
Before starting this guide, you should know how to solder. You can reference iFixit’s soldering guide here.
Qué necesitas
Remove the headphone jack cover with tweezers by grabbing it and pulling directly up and away from the device.
Use the metal spudger to push out the lock of the battery compartment by putting the metal spudger between the kickstand and the plastic and applying a force upwards.
Remove the wire from the PCB by pulling it towards the edge of the headphone jack using tweezers.
Peel off the ribbon wire using tweezers, and disconnect it from the motherboard.
