Saltar al contenido principal
Lenovo Yoga Tablet 10 Headphone Jack Replacement
Qué necesitas
  1. Lenovo Yoga Tablet 10 Headphone Jack Replacement, Back Cover: paso 1, imagen 1 de 1
    • Remove the two Phillips #000 screws.
    • These screws are located behind the stand for the device.
    • Our device did not include these screws.
  2. Lenovo Yoga Tablet 10 Headphone Jack Replacement: paso 2, imagen 1 de 1
    • Use a plastic iFixit opening tool to pry the edges of the back case loose by placing it in between the edge of the cover and the screen.
    • Do not immediately attempt to remove the back of the case without attempting Step three, or you risk snapping the back cover.
  3. Lenovo Yoga Tablet 10 Headphone Jack Replacement: paso 3, imagen 1 de 2 Lenovo Yoga Tablet 10 Headphone Jack Replacement: paso 3, imagen 2 de 2
    • Use the spudger to reach into the center of the device and pry off the back case by giving it a light force upwards.
  4. Lenovo Yoga Tablet 10 Headphone Jack Replacement, Headphone Jack: paso 4, imagen 1 de 2 Lenovo Yoga Tablet 10 Headphone Jack Replacement, Headphone Jack: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Remove the headphone jack cover with tweezers by grabbing it and pulling directly up and away from the device.
  5. Lenovo Yoga Tablet 10 Headphone Jack Replacement: paso 5, imagen 1 de 3 Lenovo Yoga Tablet 10 Headphone Jack Replacement: paso 5, imagen 2 de 3 Lenovo Yoga Tablet 10 Headphone Jack Replacement: paso 5, imagen 3 de 3
    • Remove the two 3.5mm screws using the Phillips #00 Screwdriver.
  6. Lenovo Yoga Tablet 10 Headphone Jack Replacement: paso 6, imagen 1 de 3 Lenovo Yoga Tablet 10 Headphone Jack Replacement: paso 6, imagen 2 de 3 Lenovo Yoga Tablet 10 Headphone Jack Replacement: paso 6, imagen 3 de 3
    • Disconnect the headphone jack from the motherboard by placing the spudger in between the connections and motherboard and pushing up towards you.
    • Pull the wire towards the headphone jack to disconnect it.
  7. Lenovo Yoga Tablet 10 Headphone Jack Replacement: paso 7, imagen 1 de 2 Lenovo Yoga Tablet 10 Headphone Jack Replacement: paso 7, imagen 2 de 2
    • Use tweezers to remove the headphone jack by pulling it up and towards you.
Conclusión
Una persona más ha completado esta guía.
Mahima
Miembro Desde 01/24/19
234 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S2-G6, White Winter 2019 Miembro de Cal Poly, Team S2-G6, White Winter 2019
CPSU-WHITE-W19S2G6
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 4
Ultimos 30 días: 9
Todo El Tiempo: 734
