Saltar al contenido principal
Lenovo Yoga Tab 3 10 Wifi Module Replacement
Qué necesitas
  1. Lenovo Yoga Tab 3 10 Wifi Module Replacement, Back Cover: paso 1, imagen 1 de 1
    • Open the built-in kickstand.
  2. Lenovo Yoga Tab 3 10 Wifi Module Replacement: paso 2, imagen 1 de 3 Lenovo Yoga Tab 3 10 Wifi Module Replacement: paso 2, imagen 2 de 3 Lenovo Yoga Tab 3 10 Wifi Module Replacement: paso 2, imagen 3 de 3
    • Remove the sticker located directly under the the built-in kickstand to reveal two 0.75 mm screws.
    • Remove the microSD card slot cover. Remove any microSD card (if inserted).
    • Using a Phillips head screwdriver, remove the three 0.75 mm screws.
  3. Lenovo Yoga Tab 3 10 Wifi Module Replacement: paso 3, imagen 1 de 3 Lenovo Yoga Tab 3 10 Wifi Module Replacement: paso 3, imagen 2 de 3 Lenovo Yoga Tab 3 10 Wifi Module Replacement: paso 3, imagen 3 de 3
    • Orient the device so the screen is facing you.
    • Carefully insert the spudger along the seam between the screen and back cover and gently separate the back cover from the device frame.
    • Continue to detach the backplate from the frame by moving the spudger around the perimeter.
    • Some force will be required to detach the small plastic braces securing the backplate to the device.
  4. Lenovo Yoga Tab 3 10 Wifi Module Replacement, Wifi Module: paso 4, imagen 1 de 2 Lenovo Yoga Tab 3 10 Wifi Module Replacement, Wifi Module: paso 4, imagen 2 de 2
    • Use the nylon spudger to gently lift the foil cover of the wifi model.
  5. Lenovo Yoga Tab 3 10 Wifi Module Replacement: paso 5, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Use tweezers to gently lift the gold tape located above the copper foil.
  6. Lenovo Yoga Tab 3 10 Wifi Module Replacement: paso 6, imagen 1 de 1
    • Use the plastic spudger to disconnect the wifi module connector from the motherboard.
  7. Lenovo Yoga Tab 3 10 Wifi Module Replacement: paso 7, imagen 1 de 2 Lenovo Yoga Tab 3 10 Wifi Module Replacement: paso 7, imagen 2 de 2
    • Carefully lift the wifi module from the device.
Conclusión
Una persona más ha completado esta guía.
Phanudej
Miembro Desde 02/20/17
1,190 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S3-G2, Sullivan Spring 2017 Miembro de USF Tampa, Team S3-G2, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G2
Miembros de 4
18 Guías creadas
Un comentario
where can i buy this type of module?
rebeca rackolavsci - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 38
Todo El Tiempo: 3,732
