Saltar al contenido principal
Lenovo Yoga Tab 3 10 Camera Replacement
Qué necesitas
  1. Lenovo Yoga Tab 3 10 Camera Replacement, Back Cover: paso 1, imagen 1 de 1
    • Open the built-in kickstand.
  2. Lenovo Yoga Tab 3 10 Camera Replacement: paso 2, imagen 1 de 3 Lenovo Yoga Tab 3 10 Camera Replacement: paso 2, imagen 2 de 3 Lenovo Yoga Tab 3 10 Camera Replacement: paso 2, imagen 3 de 3
    • Remove the sticker located directly under the the built-in kickstand to reveal two 0.75 mm screws.
    • Remove the microSD card slot cover. Remove any microSD card (if inserted).
    • Using a Phillips head screwdriver, remove the three 0.75 mm screws.
  3. Lenovo Yoga Tab 3 10 Camera Replacement: paso 3, imagen 1 de 3 Lenovo Yoga Tab 3 10 Camera Replacement: paso 3, imagen 2 de 3 Lenovo Yoga Tab 3 10 Camera Replacement: paso 3, imagen 3 de 3
    • Orient the device so the screen is facing you.
    • Carefully insert the spudger along the seam between the screen and back cover and gently separate the back cover from the device frame.
    • Continue to detach the backplate from the frame by moving the spudger around the perimeter.
    • Some force will be required to detach the small plastic braces securing the backplate to the device.
  4. Lenovo Yoga Tab 3 10 Camera Replacement, Camera: paso 4, imagen 1 de 3 Lenovo Yoga Tab 3 10 Camera Replacement, Camera: paso 4, imagen 2 de 3 Lenovo Yoga Tab 3 10 Camera Replacement, Camera: paso 4, imagen 3 de 3
    • Remove the 3 screws from the auxiliary port cover.
    • Use the spudger to gently push the auxiliary module out of the way.
    • Remove the detachable plastic latch located in front of the hinge.
  5. Lenovo Yoga Tab 3 10 Camera Replacement: paso 5, imagen 1 de 1
    • Use a spudger to gently remove the hinge.
  6. Lenovo Yoga Tab 3 10 Camera Replacement: paso 6, imagen 1 de 1
    • Carefully lift the kickstand away from the frame.
    • The battery is located inside of the kickstand. Ensure proper handling and care.
  7. Lenovo Yoga Tab 3 10 Camera Replacement: paso 7, imagen 1 de 2 Lenovo Yoga Tab 3 10 Camera Replacement: paso 7, imagen 2 de 2
    • Use the pointed end of a spudger to push in the camera's locking mechanism.
    • Upon releasing the camera lock lift the camera out and locate the three screws.
  8. Lenovo Yoga Tab 3 10 Camera Replacement: paso 8, imagen 1 de 3 Lenovo Yoga Tab 3 10 Camera Replacement: paso 8, imagen 2 de 3 Lenovo Yoga Tab 3 10 Camera Replacement: paso 8, imagen 3 de 3
    • Use a J000 Philips screwdriver to remove the three screws.
    • Remove the camera cover that seals the camera case.
    • Remove the camera from the shell.
  9. Lenovo Yoga Tab 3 10 Camera Replacement: paso 9, imagen 1 de 1
    • Separate the camera from its casing.
Conclusión
2 personas más completaron esta guía.
Phanudej
Miembro Desde 02/20/17
1,184 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S3-G2, Sullivan Spring 2017 Miembro de USF Tampa, Team S3-G2, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G2
4 Miembros
18 Guías creadas
Un comentario
Thanks for describing in details with bit and peaces very neatly and clearly. I fix the problem of my Lenovo Yoga 3 with help of this. Great job you have done.. keep it up… Sisira
Sisira Kumara - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 19
Todo El Tiempo: 4,108
