Saltar al contenido principal
Lenovo Yoga Tab 3 10 Motherboard Replacement
Qué necesitas
  1. Lenovo Yoga Tab 3  10 Motherboard Replacement, Back Cover: paso 1, imagen 1 de 1
    • Open the built-in kickstand.
  2. Lenovo Yoga Tab 3  10 Motherboard Replacement: paso 2, imagen 1 de 3 Lenovo Yoga Tab 3  10 Motherboard Replacement: paso 2, imagen 2 de 3 Lenovo Yoga Tab 3  10 Motherboard Replacement: paso 2, imagen 3 de 3
    • Remove the sticker located directly under the the built-in kickstand to reveal two 0.75 mm screws.
    • Remove the microSD card slot cover. Remove any microSD card (if inserted).
    • Using a Phillips head screwdriver, remove the three 0.75 mm screws.
  3. Lenovo Yoga Tab 3  10 Motherboard Replacement: paso 3, imagen 1 de 3 Lenovo Yoga Tab 3  10 Motherboard Replacement: paso 3, imagen 2 de 3 Lenovo Yoga Tab 3  10 Motherboard Replacement: paso 3, imagen 3 de 3
    • Orient the device so the screen is facing you.
    • Carefully insert the spudger along the seam between the screen and back cover and gently separate the back cover from the device frame.
    • Continue to detach the backplate from the frame by moving the spudger around the perimeter.
    • Some force will be required to detach the small plastic braces securing the backplate to the device.
  4. Lenovo Yoga Tab 3  10 Motherboard Replacement, Motherboard: paso 4, imagen 1 de 3 Lenovo Yoga Tab 3  10 Motherboard Replacement, Motherboard: paso 4, imagen 2 de 3 Lenovo Yoga Tab 3  10 Motherboard Replacement, Motherboard: paso 4, imagen 3 de 3
    • Locate the screws in the motherboard the wire cover assembly and the speakers.
    • Use the J000 screwdriver to remove the screws on the motherboard, the wire cover, and the two speakers.
    • Disconnect the wifi connector on the motherboard.
  5. Lenovo Yoga Tab 3  10 Motherboard Replacement: paso 5, imagen 1 de 2 Lenovo Yoga Tab 3  10 Motherboard Replacement: paso 5, imagen 2 de 2
    • Use the spudger to lift the two speakers up from the small adhesive strip.
    • Place the spudger in the upper left corner of the motherboard and lift it to separate it from the adhesive strip under it.
    • Lift away the motherboard.
Conclusión
15 personas más completaron esta guía.
Phanudej
Miembro Desde 02/20/17
1,190 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S3-G2, Sullivan Spring 2017 Miembro de USF Tampa, Team S3-G2, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G2
Miembros de 4
18 Guías creadas
Un comentario
Dear @phanudej ,
I liked your post. I’d have a remark and a question. I made a mistake during the maintanance; with wich I killed a part of the MOBO. So dear users my advice if you want to connect the LCD connector remove the battery before… I had never this issue but now happened. (the device was switched off)
Could you please take a photo of the powerstage of the LCD (I think it should be that) So between the inductor (100; 10uH coil) and an capacity there is a component I do not know what is it (it smoked away) I assume it is a diode…?! They are in the white rectangle near the LCD connector
Thanks in advance
Best regards
@harrincourt
Jozsef Szlatki - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 46
Todo El Tiempo: 9,499
