Saltar al contenido principal
Lenovo Yoga C940-14IIL Battery Replacement
Qué necesitas
  1. Lenovo Yoga C940-14IIL Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Flip over the laptop so that the underside is facing you.
  2. Lenovo Yoga C940-14IIL Battery Replacement: paso 2, imagen 1 de 3 Lenovo Yoga C940-14IIL Battery Replacement: paso 2, imagen 2 de 3 Lenovo Yoga C940-14IIL Battery Replacement: paso 2, imagen 3 de 3
    • Using a plastic opening tool, remove the rubber foot.
  3. Lenovo Yoga C940-14IIL Battery Replacement: paso 3, imagen 1 de 3 Lenovo Yoga C940-14IIL Battery Replacement: paso 3, imagen 2 de 3 Lenovo Yoga C940-14IIL Battery Replacement: paso 3, imagen 3 de 3
    • Using the Phillips #0 screwdriver, remove the three screws underneath the rubber foot.
  4. Lenovo Yoga C940-14IIL Battery Replacement: paso 4, imagen 1 de 3 Lenovo Yoga C940-14IIL Battery Replacement: paso 4, imagen 2 de 3 Lenovo Yoga C940-14IIL Battery Replacement: paso 4, imagen 3 de 3
    • Using the T5 Torx screwdriver, remove the four remaining screws on the outside of the frame.
  5. Lenovo Yoga C940-14IIL Battery Replacement: paso 5, imagen 1 de 3 Lenovo Yoga C940-14IIL Battery Replacement: paso 5, imagen 2 de 3 Lenovo Yoga C940-14IIL Battery Replacement: paso 5, imagen 3 de 3
    • Starting at the top and working around, carefully pry open the bottom cover.
  6. Lenovo Yoga C940-14IIL Battery Replacement: paso 6, imagen 1 de 3 Lenovo Yoga C940-14IIL Battery Replacement: paso 6, imagen 2 de 3 Lenovo Yoga C940-14IIL Battery Replacement: paso 6, imagen 3 de 3
    • It is ok to use a little force when working around. Don't panic if you hear a few pops as you are doing this.
    • Remove the back cover from the device.
  7. Lenovo Yoga C940-14IIL Battery Replacement: paso 7, imagen 1 de 3 Lenovo Yoga C940-14IIL Battery Replacement: paso 7, imagen 2 de 3 Lenovo Yoga C940-14IIL Battery Replacement: paso 7, imagen 3 de 3
    • The battery is held in place by four screws, one of which is hidden.
    • Remove this small piece of rubber is covering one of the screws with your fingers.
  8. Lenovo Yoga C940-14IIL Battery Replacement: paso 8, imagen 1 de 2 Lenovo Yoga C940-14IIL Battery Replacement: paso 8, imagen 2 de 2
    • Use the Phillips #0 screwdriver to remove the four screws securing the battery to the device.
  9. Lenovo Yoga C940-14IIL Battery Replacement: paso 9, imagen 1 de 2 Lenovo Yoga C940-14IIL Battery Replacement: paso 9, imagen 2 de 2
    • To complete the removal of the battery, disconnect the ribbon cable connecting the battery to the computer.
  10. Lenovo Yoga C940-14IIL Battery Replacement: paso 10, imagen 1 de 1
    • Remove the battery from the device.
Conclusión
For optimal performance, after completing this guide, calibrate your newly installed battery.
Una persona más ha completado esta guía.
4 comentarios
Thanks a lot for the clear and thorough guidelines, worked like a charm and saved my 2-year old C940 after its original battery has bloated on its own!
Leonid Glazychev - Contestar
Purhcased a replacement laptop battery from CanadaLaptopBattery, they shopped it from overseas (AlosteCell). Followed this guide to replace the battery. Replacing that little rubber piece was probably the biggest pain in the butt (the wire for the right speaker wraps around the rubber at the bottom as you squeeze it in). Thanks to the guide, this was one of the rare times I grabbed the right Torx bit first-try! Just a note; My laptop took several minutes after putting the new battery in (as well as being plugged in) to turn on. The laptop was on as indicated by the powerlight on the side, and the laptop was charging (orange light on the other side), but probably took 2-3 minutes to POST (Lenovo logo on screen). Just thought I'd mention that in case anyone freaks out.
Calvin Ing - Contestar
Thanks for the helpful instructions! I have a question though: do you think it’s a bigger problem that I didn’t get the little screw underneath the small rubber thing back in? Because the new battery was built in a way that it wouldn’t fit.
lukas.palla - Contestar
This does not show the inside of a Yoga C-940. The battery has 5 screws.
Edmund Jones - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 11
Ultimos 7 días: 63
Ultimos 30 días: 278
Todo El Tiempo: 8,814
