Saltar al contenido principal
Lenovo Yoga Book X90F Speakers Replacement
Qué necesitas
  1. Lenovo Yoga Book X90F Speakers Replacement, Bottom Screen/Keyboard: paso 1, imagen 1 de 1
    • Turn off and power down the device before beginning this process. A heat gun or hair dryer will be suitable to heat the adhesive that holds down the screen. Apply heat to the entire surface area of the bottom screen.
    • New adhesive will be required when completing the steps in reverse order.
  2. Lenovo Yoga Book X90F Speakers Replacement: paso 2, imagen 1 de 2 Lenovo Yoga Book X90F Speakers Replacement: paso 2, imagen 2 de 2
    • Once the adhesive has been heated up, take the iFixIt suction cup and lift in a corner. The screen should be separating from the adhesive here.
    • While the screen is lifted, insert the ifixit opening pick to help pry off the screen.
    • The screen may crack easily as it is thin and fragile.
  3. Lenovo Yoga Book X90F Speakers Replacement: paso 3, imagen 1 de 1
    • While the screen has been lifted, insert the plastic opening picks. Heat the adhesive and follow with the screen removal tool to ensure that you are not prying it apart with excessive force.
  4. Lenovo Yoga Book X90F Speakers Replacement: paso 4, imagen 1 de 3 Lenovo Yoga Book X90F Speakers Replacement: paso 4, imagen 2 de 3 Lenovo Yoga Book X90F Speakers Replacement: paso 4, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • After the screen has been opened, disconnect the ribbon connecting the bottom screen to the motherboard by gently pulling the ribbon with tweezers.
    • If there are black coverings on the tabs as shown in the second image, carefully remove them using a pair of tweezers.
    • You can find more information on Zero Insertion Force (ZIF) connectors on this guide.
  5. Lenovo Yoga Book X90F Speakers Replacement: paso 5, imagen 1 de 1
    • Separate and remove the bottom screen from the device.
  6. Lenovo Yoga Book X90F Speakers Replacement, Right and Left Speakers: paso 6, imagen 1 de 3 Lenovo Yoga Book X90F Speakers Replacement, Right and Left Speakers: paso 6, imagen 2 de 3 Lenovo Yoga Book X90F Speakers Replacement, Right and Left Speakers: paso 6, imagen 3 de 3
    Comprar
    • Peel the yellowish covering off, using the flat end of the spudger to pry it up and the tweezers to pull it off gently.
  7. Lenovo Yoga Book X90F Speakers Replacement: paso 7, imagen 1 de 2 Lenovo Yoga Book X90F Speakers Replacement: paso 7, imagen 2 de 2
    • Remove black covering from device.
  8. Lenovo Yoga Book X90F Speakers Replacement: paso 8, imagen 1 de 2 Lenovo Yoga Book X90F Speakers Replacement: paso 8, imagen 2 de 2
    • Use tweezers to unplug the intertwined black and red wires.
  9. Lenovo Yoga Book X90F Speakers Replacement: paso 9, imagen 1 de 1
    • Using the JIS #00 screwdriver, remove the three 8 mm screws that are holding the right speaker down.
  10. Lenovo Yoga Book X90F Speakers Replacement: paso 10, imagen 1 de 1
    • Using the tweezers, remove the right speaker from the device.
    • The speaker is snugly fit under the lip of the device.
  11. Lenovo Yoga Book X90F Speakers Replacement: paso 11, imagen 1 de 2 Lenovo Yoga Book X90F Speakers Replacement: paso 11, imagen 2 de 2
    • Use tweezers to unplug the intertwined red and black wires.
  12. Lenovo Yoga Book X90F Speakers Replacement: paso 12, imagen 1 de 2 Lenovo Yoga Book X90F Speakers Replacement: paso 12, imagen 2 de 2
    • Using the JIS #00 screwdriver, remove the two 8 mm screws that are holding the left speaker down.
  13. Lenovo Yoga Book X90F Speakers Replacement: paso 13, imagen 1 de 2 Lenovo Yoga Book X90F Speakers Replacement: paso 13, imagen 2 de 2
    • Use the spudger to gently pry the left speaker up.
    • Use the tweezers to pull the left speaker out.
Conclusión
McKenzy Butler
Miembro Desde 09/28/21
157 Reputación
1 Guía escrita
Equipo
Clemson, Team 5-2, Hunter Fall 2021 Miembro de Clemson, Team 5-2, Hunter Fall 2021
CLEM-HUNTER-F21S5G2
5 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 213
