Saltar al contenido principal
Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement
Qué necesitas
  1. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement, Back Cover: paso 1, imagen 1 de 2 Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement, Back Cover: paso 1, imagen 2 de 2
    • Flip the device over to access the screws on the back cover.
    • Remove the ten 5mm Torx T5 screws on the back cover to loosen the back cover.
  2. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: paso 2, imagen 1 de 3 Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: paso 2, imagen 2 de 3 Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: paso 2, imagen 3 de 3
    • Slide the iFixit Opening Tool under the back cover to lift it up.
    • Pull up on the cover with your hand to release the tab holding the center of the cover in place.
  3. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement, Battery: paso 3, imagen 1 de 3 Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement, Battery: paso 3, imagen 2 de 3 Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement, Battery: paso 3, imagen 3 de 3
    • Remove the four 5mm Phillips #00 screws that hold the battery in place.
  4. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: paso 4, imagen 1 de 2 Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: paso 4, imagen 2 de 2
    • Grab the grouping of wires with your fingers close to the connector and gently pull to disconnect the battery from the motherboard.
    • The wire grouping is located underneath the thin flap near the center of the battery.
    • Do not lift the battery out before disconnection from the motherboard to prevent shortages or damage.
  5. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: paso 5, imagen 1 de 1
    • Use the iFixit Opening Tool to lift the battery up enough to grab it with your hands.
  6. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: paso 6, imagen 1 de 1
    • Remove the battery.
  7. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement, Fingerprint Sensor: paso 7, imagen 1 de 1
    • Remove the 3mm Phillips #00 Screw to loosen the sensor.
  8. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: paso 8, imagen 1 de 1
    • Lift up the cover on the fingerprint sensor using the iFixit Opening Tool and remove the cover from the sensor.
  9. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: paso 9, imagen 1 de 1
    • Flip up the cable connector tab using the iFixit Opening Tool to release the ribbon wire.
  10. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: paso 10, imagen 1 de 1
    • Unplug the ribbon wire from the sensor to completely free the sensor.
  11. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: paso 11, imagen 1 de 1
    • Lift the fingerprint sensor with the iFixit Opening Tool and remove it from the device.
Conclusión
Alyssa McCulloch
Miembro Desde 01/24/19
1,921 Reputación
9 Guías creadas
Equipo
Cal Poly, Team S2-G3, White Winter 2019 Miembro de Cal Poly, Team S2-G3, White Winter 2019
CPSU-WHITE-W19S2G3
4 Miembros
29 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 12
Todo El Tiempo: 591
