Saltar al contenido principal
Lenovo Yoga 920-13IKB Audio Jack Replacement
Qué necesitas
  1. Lenovo Yoga 920-13IKB Audio Jack Replacement, Back Cover: paso 1, imagen 1 de 2 Lenovo Yoga 920-13IKB Audio Jack Replacement, Back Cover: paso 1, imagen 2 de 2
    • Flip the device over to access the screws on the back cover.
    • Remove the ten 5mm Torx T5 screws on the back cover to loosen the back cover.
  2. Lenovo Yoga 920-13IKB Audio Jack Replacement: paso 2, imagen 1 de 3 Lenovo Yoga 920-13IKB Audio Jack Replacement: paso 2, imagen 2 de 3 Lenovo Yoga 920-13IKB Audio Jack Replacement: paso 2, imagen 3 de 3
    • Slide the iFixit Opening Tool under the back cover to lift it up.
    • Pull up on the cover with your hand to release the tab holding the center of the cover in place.
  3. Lenovo Yoga 920-13IKB Audio Jack Replacement, Motherboard: paso 3, imagen 1 de 2 Lenovo Yoga 920-13IKB Audio Jack Replacement, Motherboard: paso 3, imagen 2 de 2
    • Remove the twelve 5mm Phillips #00 screws to loosen the motherboard.
  4. Lenovo Yoga 920-13IKB Audio Jack Replacement: paso 4, imagen 1 de 3 Lenovo Yoga 920-13IKB Audio Jack Replacement: paso 4, imagen 2 de 3 Lenovo Yoga 920-13IKB Audio Jack Replacement: paso 4, imagen 3 de 3
    • Flip up the ten flat connectors holding the motherboard using the iFixit Opening Tool to free the motherboard.
  5. Lenovo Yoga 920-13IKB Audio Jack Replacement: paso 5, imagen 1 de 2 Lenovo Yoga 920-13IKB Audio Jack Replacement: paso 5, imagen 2 de 2
    • Pull out the ribbon cables from the opened connectors using the iFixit Tweezers to free up the motherboard.
  6. Lenovo Yoga 920-13IKB Audio Jack Replacement: paso 6, imagen 1 de 2 Lenovo Yoga 920-13IKB Audio Jack Replacement: paso 6, imagen 2 de 2
    • Disconnect the battery by pulling the ribbon wire grouping out of the top of the motherboard.
  7. Lenovo Yoga 920-13IKB Audio Jack Replacement: paso 7, imagen 1 de 2 Lenovo Yoga 920-13IKB Audio Jack Replacement: paso 7, imagen 2 de 2
    • Disconnect the red and black wire from the motherboard using the iFixit Tweezers.
  8. Lenovo Yoga 920-13IKB Audio Jack Replacement: paso 8, imagen 1 de 3 Lenovo Yoga 920-13IKB Audio Jack Replacement: paso 8, imagen 2 de 3 Lenovo Yoga 920-13IKB Audio Jack Replacement: paso 8, imagen 3 de 3
    • Lift the motherboard up parallel to the hinge of the device.
    • Gently pull away from the port cutouts of the USB-C and audio jack to remove the motherboard from the device casing.
    • Avoid pulling the motherboard all the way out until the green AC card is disconnected.
  9. Lenovo Yoga 920-13IKB Audio Jack Replacement: paso 9, imagen 1 de 3 Lenovo Yoga 920-13IKB Audio Jack Replacement: paso 9, imagen 2 de 3 Lenovo Yoga 920-13IKB Audio Jack Replacement: paso 9, imagen 3 de 3
    • Disconnect the green AC card plugged into the motherboard by pulling it out with your hands.
  10. Lenovo Yoga 920-13IKB Audio Jack Replacement: paso 10, imagen 1 de 1
    • Flip the motherboard over to access the back side.
  11. Lenovo Yoga 920-13IKB Audio Jack Replacement: paso 11, imagen 1 de 3 Lenovo Yoga 920-13IKB Audio Jack Replacement: paso 11, imagen 2 de 3 Lenovo Yoga 920-13IKB Audio Jack Replacement: paso 11, imagen 3 de 3
    • Remove four 3mm JIS #00 screws with the screwdriver.
    • Remove one 3mm Phillips #00 screw with the screwdriver.
    • The screws stay attached to the speaker when removed from the motherboard.
  12. Lenovo Yoga 920-13IKB Audio Jack Replacement: paso 12, imagen 1 de 1
    • Separate the fans from the motherboard to isolate it for replacement.
  13. Lenovo Yoga 920-13IKB Audio Jack Replacement, Audio Jack: paso 13, imagen 1 de 1
    • Replace the motherboard to replace the audio jack.
Conclusión
Alyssa McCulloch
Miembro Desde 01/24/19
1,891 Reputación
9 Guías creadas
Equipo
Cal Poly, Team S2-G3, White Winter 2019 Miembro de Cal Poly, Team S2-G3, White Winter 2019
CPSU-WHITE-W19S2G3
4 Miembros
29 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 780
