Saltar al contenido principal
Lenovo Yoga 910-13IKB Wi-Fi Card Replacement
Qué necesitas
  1. Lenovo Yoga 910-13IKB Wi-Fi Card Replacement, Back Panel: paso 1, imagen 1 de 2 Lenovo Yoga 910-13IKB Wi-Fi Card Replacement, Back Panel: paso 1, imagen 2 de 2
    • Turn the laptop over and remove the ten Torx T5 screws along the perimeter of the bottom panel using the T5 Torx Screwdriver.
    • Remove the back panel from the device exposing the components.
  2. Lenovo Yoga 910-13IKB Wi-Fi Card Replacement, Battery: paso 2, imagen 1 de 1
    • Remove the four 3 mm Phillips #0 screws holding the battery in place.
  3. Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: paso 3, imagen 1 de 3 Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: paso 3, imagen 2 de 3 Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: paso 3, imagen 3 de 3
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery. The spudger tool may be needed to lift the flap seal.
    • Pull parallel to the battery, not straight up.
    • Pull evenly on the width of the cable so that no individual wire is overly strained.
    • Lift the battery out.
  4. Lenovo Yoga 910-13IKB Wi-Fi Card Replacement, Wi-Fi Card: paso 4, imagen 1 de 1
    • Remove the single 1 mm screw at left of Wi-Fi card with a Phillips #0 screwdriver.
  5. Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: paso 5, imagen 1 de 2 Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: paso 5, imagen 2 de 2
    • Pull the Wi-Fi card out of the slot on the motherboard.
    • It is still connected to the coaxial cables so don't yank it out or those connections will break.
  6. Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: paso 6, imagen 1 de 3 Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: paso 6, imagen 2 de 3 Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: paso 6, imagen 3 de 3
    • Detach the white wire that is connected to the Wi-Fi card by applying gentle pressure.
    • Detach the black wire by applying gentle pressure.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 9
Ultimos 30 días: 29
Todo El Tiempo: 513
