Saltar al contenido principal
Lenovo Yoga 910-13IKB Trackpad Replacement
Qué necesitas
  1. Lenovo Yoga 910-13IKB Trackpad Replacement, Back Panel: paso 1, imagen 1 de 2 Lenovo Yoga 910-13IKB Trackpad Replacement, Back Panel: paso 1, imagen 2 de 2
    • Turn the laptop over and remove the ten Torx T5 screws along the perimeter of the bottom panel using the T5 Torx Screwdriver.
    • Remove the back panel from the device exposing the components.
  2. Lenovo Yoga 910-13IKB Trackpad Replacement, Battery: paso 2, imagen 1 de 1
    • Remove the four 3 mm Phillips #0 screws holding the battery in place.
  3. Lenovo Yoga 910-13IKB Trackpad Replacement: paso 3, imagen 1 de 3 Lenovo Yoga 910-13IKB Trackpad Replacement: paso 3, imagen 2 de 3 Lenovo Yoga 910-13IKB Trackpad Replacement: paso 3, imagen 3 de 3
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery. The spudger tool may be needed to lift the flap seal.
    • Pull parallel to the battery, not straight up.
    • Pull evenly on the width of the cable so that no individual wire is overly strained.
    • Lift the battery out.
  4. Lenovo Yoga 910-13IKB Trackpad Replacement, Trackpad: paso 4, imagen 1 de 3 Lenovo Yoga 910-13IKB Trackpad Replacement, Trackpad: paso 4, imagen 2 de 3 Lenovo Yoga 910-13IKB Trackpad Replacement, Trackpad: paso 4, imagen 3 de 3
    • Using the Phillips #0 screwdriver, remove all six screws holding the trackpad to the device.
    • Find the ribbon cable, the black bundle of wires attached to the trackpad, and lift the head of the ribbon cable towards you.
    • Carefully lift up the trackpad and remove it from the device.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 412
