Saltar al contenido principal
Lenovo Yoga 910-13IKB SSD Replacement
Qué necesitas
  1. Lenovo Yoga 910-13IKB SSD Replacement, Bottom Panel: paso 1, imagen 1 de 2 Lenovo Yoga 910-13IKB SSD Replacement, Bottom Panel: paso 1, imagen 2 de 2
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Turn the laptop over and remove the ten Torx T5 screws along the perimeter of the bottom panel.
    • Remove the panel.
  2. Lenovo Yoga 910-13IKB SSD Replacement: paso 2, imagen 1 de 1
    • Remove all 4 screws attached to the battery with a small Phillips head screwdriver.
    • Each screw on the back is M2 x 1.7mm
    • After the screws are taken out, remove the battery.
  3. Lenovo Yoga 910-13IKB SSD Replacement: paso 3, imagen 1 de 1
    • Remove all 6 screws attached to the trackpad with a small Phillips head screwdriver.
    • Detach the ribbon cable connected to the trackpad using a wedge device.
    • Remove the trackpad using a wedge device
  4. Lenovo Yoga 910-13IKB SSD Replacement: paso 4, imagen 1 de 1
    • Remove all 6 screws attached to the USB ports on both sides of the device with a small Philips head screwdriver.
    • Detach both ribbon cables attached to each USB port with a wedge device, then detach the USB ports.
  5. Lenovo Yoga 910-13IKB SSD Replacement: paso 5, imagen 1 de 3 Lenovo Yoga 910-13IKB SSD Replacement: paso 5, imagen 2 de 3 Lenovo Yoga 910-13IKB SSD Replacement: paso 5, imagen 3 de 3
    • Remove all 4 screws attached to SSD stick with a small Phillips head screwdriver.
    • Pull the SSD stick directly to the right until it shifts out of place to remove it.
    • The storage chip above it (further away from you) may also simply be detached by pulling it directly to the right until it clicks out.
  6. Lenovo Yoga 910-13IKB SSD Replacement: paso 6, imagen 1 de 3 Lenovo Yoga 910-13IKB SSD Replacement: paso 6, imagen 2 de 3 Lenovo Yoga 910-13IKB SSD Replacement: paso 6, imagen 3 de 3
    • Remove all 4 screws attached to both fans, and the back connector strip (long metal piece furthest from you with screws in it) with a small Phillips head screwdriver
    • Remove the back connector strip using a wedge device to pry it off of the device
    • With the back connector strip removed, pry the fans (which are attached) using a wedge device and the fans will now be maintainable.
  7. Lenovo Yoga 910-13IKB SSD Replacement, SSD: paso 7, imagen 1 de 1
    • Remove the 3mm JIS #00 screw holding the storage in place.
  8. Lenovo Yoga 910-13IKB SSD Replacement: paso 8, imagen 1 de 2 Lenovo Yoga 910-13IKB SSD Replacement: paso 8, imagen 2 de 2
    • Pull up lightly on the drive and gently pull it out of the connector.
Conclusión
Nikhil Nagarajan
Miembro Desde 01/23/20
97 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S1-G5, White Winter 2020 Miembro de Cal Poly, Team S1-G5, White Winter 2020
CPSU-WHITE-W20S1G5
4 Miembros
14 Guías creadas
Un comentario
Just one question: if I want to replace just the SSD, surely one goes straight from step one to step seven?
Bessi Aðalsteinsson - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 32
Ultimos 30 días: 81
Todo El Tiempo: 6,511
