Saltar al contenido principal
Lenovo Yoga 730-13IKB Storage Replacement
Qué necesitas
  1. Lenovo Yoga 730-13IKB Storage Replacement, Back Case: paso 1, imagen 1 de 3 Lenovo Yoga 730-13IKB Storage Replacement, Back Case: paso 1, imagen 2 de 3 Lenovo Yoga 730-13IKB Storage Replacement, Back Case: paso 1, imagen 3 de 3
    • Power off the laptop and place it facedown on a non-scratching surface.
    • Remove the nine T5 screws fastening the back case.
  2. Lenovo Yoga 730-13IKB Storage Replacement: paso 2, imagen 1 de 3 Lenovo Yoga 730-13IKB Storage Replacement: paso 2, imagen 2 de 3 Lenovo Yoga 730-13IKB Storage Replacement: paso 2, imagen 3 de 3
    • Slide a plastic opening tool underneath the back case near the screen hinges. Gently pry up on either side.
    • Slide the opening tool underneath the back case next to the middle screw hole at either side of the case. Gently pry up.
    • You may hear popping sounds as the tabs securing the case release. This is normal. If the case does not move, try prying at a different angle/position.
  3. Lenovo Yoga 730-13IKB Storage Replacement: paso 3, imagen 1 de 1
    • Remove the back case by pulling up near the screen hinges and lifting diagonally away from the laptop.
    • Go slowly to avoid breaking any connecting tabs.
  4. Lenovo Yoga 730-13IKB Storage Replacement, Storage: paso 4, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the 4mm screw holding down the storage drive.
  5. Lenovo Yoga 730-13IKB Storage Replacement: paso 5, imagen 1 de 2 Lenovo Yoga 730-13IKB Storage Replacement: paso 5, imagen 2 de 2
    • Hold onto the back of the storage drive and slightly lift up.
    • Remove the drive by pulling back at a diagonal angle.
    • To install the storage drive, insert it into the connector at a slight downwards angle. The drive connector is keyed and will only go in one way.
Conclusión
Una persona más ha completado esta guía.
Colin Reay
Miembro Desde 01/23/20
848 Reputación
5 Guías creadas
Equipo
Cal Poly, Team S1-G1, White Winter 2020 Miembro de Cal Poly, Team S1-G1, White Winter 2020
CPSU-WHITE-W20S1G1
3 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 34
Todo El Tiempo: 1,392
