Saltar al contenido principal
Lenovo Yoga 730-13IKB Heat Sink Replacement
Qué necesitas
  1. Lenovo Yoga 730-13IKB Heat Sink Replacement, Back Case: paso 1, imagen 1 de 3 Lenovo Yoga 730-13IKB Heat Sink Replacement, Back Case: paso 1, imagen 2 de 3 Lenovo Yoga 730-13IKB Heat Sink Replacement, Back Case: paso 1, imagen 3 de 3
    • Power off the laptop and place it facedown on a non-scratching surface.
    • Remove the nine T5 screws fastening the back case.
  2. Lenovo Yoga 730-13IKB Heat Sink Replacement: paso 2, imagen 1 de 3 Lenovo Yoga 730-13IKB Heat Sink Replacement: paso 2, imagen 2 de 3 Lenovo Yoga 730-13IKB Heat Sink Replacement: paso 2, imagen 3 de 3
    • Slide a plastic opening tool underneath the back case near the screen hinges. Gently pry up on either side.
    • Slide the opening tool underneath the back case next to the middle screw hole at either side of the case. Gently pry up.
    • You may hear popping sounds as the tabs securing the case release. This is normal. If the case does not move, try prying at a different angle/position.
  3. Lenovo Yoga 730-13IKB Heat Sink Replacement: paso 3, imagen 1 de 1
    • Remove the back case by pulling up near the screen hinges and lifting diagonally away from the laptop.
    • Go slowly to avoid breaking any connecting tabs.
  4. Lenovo Yoga 730-13IKB Heat Sink Replacement, Heat Sink: paso 4, imagen 1 de 2 Lenovo Yoga 730-13IKB Heat Sink Replacement, Heat Sink: paso 4, imagen 2 de 2
    • Use a Phillips #00 screwdriver to remove the eight 2.5mm screws securing the heat sink assembly.
  5. Lenovo Yoga 730-13IKB Heat Sink Replacement: paso 5, imagen 1 de 2 Lenovo Yoga 730-13IKB Heat Sink Replacement: paso 5, imagen 2 de 2
    • Release the fan connector by gently pushing the gray locking tab up using a plastic spudger. Do this for both of the fans.
    • Pull each fan cable straight out of the connector.
  6. Lenovo Yoga 730-13IKB Heat Sink Replacement: paso 6, imagen 1 de 1
    • Remove the heat sink assembly by holding the middle plate and rotating the assembly down towards the back of the motherboard.
    • Pull the heat sink diagonally away from the laptop.
Conclusión
Una persona más ha completado esta guía.
Colin Reay
Miembro Desde 01/23/20
848 Reputación
5 Guías creadas
Equipo
Cal Poly, Team S1-G1, White Winter 2020 Miembro de Cal Poly, Team S1-G1, White Winter 2020
CPSU-WHITE-W20S1G1
3 Miembros
14 Guías creadas
Un comentario
gdje i kako kupiti hladnjak za lenovo yoga 730-13 sa zamjenu
Smajo Avdic - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 18
Ultimos 30 días: 24
Todo El Tiempo: 956
