Saltar al contenido principal
Lenovo Yoga 720-13IKB Touchpad Replacement
Qué necesitas
  1. Lenovo Yoga 720-13IKB Touchpad Replacement, Bottom Cover: paso 1, imagen 1 de 3 Lenovo Yoga 720-13IKB Touchpad Replacement, Bottom Cover: paso 1, imagen 2 de 3 Lenovo Yoga 720-13IKB Touchpad Replacement, Bottom Cover: paso 1, imagen 3 de 3
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Start by flipping the device over so that you see the screws.
    • Remove seven Torx T5 short screws.
    • Remove three Torx T5 long screws.
  2. Lenovo Yoga 720-13IKB Touchpad Replacement: paso 2, imagen 1 de 3 Lenovo Yoga 720-13IKB Touchpad Replacement: paso 2, imagen 2 de 3 Lenovo Yoga 720-13IKB Touchpad Replacement: paso 2, imagen 3 de 3
    Herramienta utilizada en este paso:
    iFixit Opening Tool
    $1.99
    • Starting from the USB port, use your opening tool to gently pry up the case.
    • Make sure you are prying on the cover itself, not the metal shield around the USB port.
    • Pry along the laptop in the order shown by the arrows.
    • Do NOT pry along the top side, or you risk damaging the casing. Stay with the arrows.
  3. Lenovo Yoga 720-13IKB Touchpad Replacement: paso 3, imagen 1 de 3 Lenovo Yoga 720-13IKB Touchpad Replacement: paso 3, imagen 2 de 3 Lenovo Yoga 720-13IKB Touchpad Replacement: paso 3, imagen 3 de 3
    • Lift the case from the bottom side. NOT the side with the hinges.
    • When you feel resistance, do NOT keep lifting or you will damage the housing.
    • Once you feel resistance, gently pull the case towards you. (away from the hinges.)
    • Remove the case.
  4. Lenovo Yoga 720-13IKB Touchpad Replacement, Battery: paso 4, imagen 1 de 3 Lenovo Yoga 720-13IKB Touchpad Replacement, Battery: paso 4, imagen 2 de 3 Lenovo Yoga 720-13IKB Touchpad Replacement, Battery: paso 4, imagen 3 de 3
    • This is the battery. For guides that are for other parts, the battery is removed for the reason of it being a pain to connect or disconnect while screwed in.
    • Be careful not to short anything on the motherboard, as the battery cannot be disconnected before removal.
    • Remove four J1 Philips screws.
    • Remove one J1 philips screw.
    • Do not mix these screws up. If you put the longer screw where the shorter screw belongs, you will damage the shield around the keyboard.
    • Lift the battery slightly using your plastic opening tool.
    • Do not lift the battery out all the way, as it is still connected to the motherboard.
    • Do NOT puncture or deform the battery or it may catch fire or even explode.
  5. Lenovo Yoga 720-13IKB Touchpad Replacement: paso 5, imagen 1 de 3 Lenovo Yoga 720-13IKB Touchpad Replacement: paso 5, imagen 2 de 3 Lenovo Yoga 720-13IKB Touchpad Replacement: paso 5, imagen 3 de 3
    • Pull the battery towards you until the wire is accessible.
    • gently tug and wiggle on the wire until it pops out.
    • Remove the battery.
  6. Lenovo Yoga 720-13IKB Touchpad Replacement, Touchpad: paso 6, imagen 1 de 2 Lenovo Yoga 720-13IKB Touchpad Replacement, Touchpad: paso 6, imagen 2 de 2
    • Use a Torx T5 screwdriver to remove the eight 8mm screws holding the touchpad in place.
  7. Lenovo Yoga 720-13IKB Touchpad Replacement: paso 7, imagen 1 de 2 Lenovo Yoga 720-13IKB Touchpad Replacement: paso 7, imagen 2 de 2
    • Lift the small black tab on the single ZIF connector in the center of the touchpad, and gently pull the white ribbon cable free.
    • Gently peel the silver conductive tape away from the touchpad shielding.
    • Do not discard the conductive tape. Reapply this strip during reassembly.
    • Remove the touchpad.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 17
Todo El Tiempo: 853
