Saltar al contenido principal
Lenovo Yoga 720-12IKB Headphone Jack Replacement
Qué necesitas
  1. Lenovo Yoga 720-12IKB Headphone Jack Replacement, Battery: paso 1, imagen 1 de 1
    • Unscrew and remove the four 5.5 mm Phillips #00 screws on the back panel.
  2. Lenovo Yoga 720-12IKB Headphone Jack Replacement: paso 2, imagen 1 de 1
    • Pull down on the cover to remove it and you will see the battery after removing the cover.
  3. Lenovo Yoga 720-12IKB Headphone Jack Replacement: paso 3, imagen 1 de 2 Lenovo Yoga 720-12IKB Headphone Jack Replacement: paso 3, imagen 2 de 2
    • Unscrew and remove the 4.0 mm Phillips #00 screws on the battery to remove it from the motherboard.
  4. Lenovo Yoga 720-12IKB Headphone Jack Replacement: paso 4, imagen 1 de 2 Lenovo Yoga 720-12IKB Headphone Jack Replacement: paso 4, imagen 2 de 2
    • Remove the battery wires from the socket on the motherboard above the battery.
  5. Lenovo Yoga 720-12IKB Headphone Jack Replacement: paso 5, imagen 1 de 1
    • Finally remove the battery from the case.
  6. Lenovo Yoga 720-12IKB Headphone Jack Replacement, Headphone Jack: paso 6, imagen 1 de 1
    • The headphone jack can be found on the top right of the chassis.
    • Start by removing the 2.0 mm Phillips #00 screw.
  7. Lenovo Yoga 720-12IKB Headphone Jack Replacement: paso 7, imagen 1 de 1
    • Undo the clip and remove the connector.
  8. Lenovo Yoga 720-12IKB Headphone Jack Replacement: paso 8, imagen 1 de 1
    • Pull the connector to the right to remove it from the clip.
  9. Lenovo Yoga 720-12IKB Headphone Jack Replacement: paso 9, imagen 1 de 1
    • Remove the headphone jack from the chassis.
Conclusión
Alex Escobar
Miembro Desde 02/10/22
778 Reputación
6 Guías creadas
Equipo
Gateway, Team 1-4, Pee Spring 2022 Miembro de Gateway, Team 1-4, Pee Spring 2022
GCC-PEE-S22S1G4
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 15
Todo El Tiempo: 220
