Saltar al contenido principal
Lenovo Yoga 710-15ISK Battery Replacement
Qué necesitas
  1. Lenovo Yoga 710-15ISK Battery Replacement, Back Cover: paso 1, imagen 1 de 2 Lenovo Yoga 710-15ISK Battery Replacement, Back Cover: paso 1, imagen 2 de 2
    • Flip your laptop over so the bottom is facing upwards.
    • Remove ten 2 mm screws securing the back cover to the laptop using a Phillips #0 screwdriver. The location of the screws is encircled in the photo.
  2. Lenovo Yoga 710-15ISK Battery Replacement: paso 2, imagen 1 de 1
    • Gently remove the back cover of the laptop with your fingers.
  3. Lenovo Yoga 710-15ISK Battery Replacement, Battery: paso 3, imagen 1 de 2 Lenovo Yoga 710-15ISK Battery Replacement, Battery: paso 3, imagen 2 de 2
    • Remove the four 2 mm screws from the battery using a Phillips #0 screwdriver.
  4. Lenovo Yoga 710-15ISK Battery Replacement: paso 4, imagen 1 de 1
    • Remove the connector between the battery and the motherboard by gently pulling the black plastic-coated part of the wires.
  5. Lenovo Yoga 710-15ISK Battery Replacement: paso 5, imagen 1 de 1
    • Remove the battery from the laptop.
Conclusión
For optimal performance, after completing this guide, calibrate your newly installed battery.
Elisa Normand
Miembro Desde 10/25/21
423 Reputación
4 Guías creadas
Equipo
UMass Dartmouth, Team 3-5, Sinclaire Fall 2021 Miembro de UMass Dartmouth, Team 3-5, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G5
2 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 16
Ultimos 30 días: 18
Todo El Tiempo: 549
