Saltar al contenido principal
Lenovo Yoga 710-15IKB Fan Replacement
Qué necesitas
  1. Lenovo Yoga 710-15IKB Fan  Replacement, Battery: paso 1, imagen 1 de 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the ten 3.3 mm T5 screws from the base cover.
    • The screws aren't all the same length. Be sure to keep the screws sorted as you work.
  2. Lenovo Yoga 710-15IKB Fan  Replacement: paso 2, imagen 1 de 1
    • Slide an opening tool between the base and back cover and work your way around the entire device to release the back cover.
  3. Lenovo Yoga 710-15IKB Fan  Replacement: paso 3, imagen 1 de 1
    • Lift and remove the back cover.
  4. Lenovo Yoga 710-15IKB Fan  Replacement: paso 4, imagen 1 de 1
    • Remove the four 3.5 mm screws around the battery using a Phillips #1 screwdriver.
  5. Lenovo Yoga 710-15IKB Fan  Replacement: paso 5, imagen 1 de 1
    • Disconnect the battery by pulling its cable away from the hinge with a pair of tweezers or your fingers.
  6. Lenovo Yoga 710-15IKB Fan  Replacement: paso 6, imagen 1 de 1
    • Gently lift and remove the battery.
  7. Lenovo Yoga 710-15IKB Fan  Replacement, Fan: paso 7, imagen 1 de 1
    • Use tweezers to grab the fan harness.
    • Gently pull the harness to disconnect from motherboard.
  8. Lenovo Yoga 710-15IKB Fan  Replacement: paso 8, imagen 1 de 1
    • Use a Phillips #1 screwdriver to remove the four screws holding down the fans.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 2,123
