Saltar al contenido principal
Lenovo Yoga 710-15IKB Back Cover Replacement
Qué necesitas
  1. Lenovo Yoga 710-15IKB Back Cover Replacement, Lenovo Yoga 710-15IKB Back Cover Replacement: paso 1, imagen 1 de 1
    • Remove the ten 3.3 mm screws from the base cover using the T5 Torx screwdriver.
  2. Lenovo Yoga 710-15IKB Back Cover Replacement: paso 2, imagen 1 de 1
    • Slide opening tool between the base and back cover.
  3. Lenovo Yoga 710-15IKB Back Cover Replacement: paso 3, imagen 1 de 1
    • Lift the back cover.
Conclusión
4 personas más completaron esta guía.
2 comentarios
Hello,
i am looking for lenovo yoga 710 15” laptop lcd and top body part, where lcd fixed. please suggest.
Thanks & Regards,
Vilas
salvivilas@gmail.com
sunilkedar - Contestar
You can get the screens for these fairly easily online, the only problem is the special command adhesive that goes with it doesn’t exist. I have been struggling to get this screen to stick using the recommended 3m adhesive alternative. The screen just wont stick! It appears to stick for weeks without issue but eventually this fails.
service - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 13
Todo El Tiempo: 3,199
