Introducción
This guide will demonstrate how to replace the Wi-Fi card in your Lenovo Yoga laptop.
Qué necesitas
Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
Peel off the black tape covering the top of the WiFi card.
Remove the black and white antenna cable attached to the card by pulling them off using the precison tweezers.
7 personas más completaron esta guía.
Un comentario
I haven’t done it yet, but I’m no longer worried in the slightest! Your guide is about as dummy friendly as it gets, and I cannot even tell you how helpful your detailed instructions, ALONG WITH EXACT, CLEAR, and zoom-able pics of every step , PLUS warnings of what NOT to do and how to tell if you’ve screwed it up!!! A breath of fresh air compared what I’ve come to expect anymore online. I get ones like this - a super fast video, cam behind the person, too far away to see what they’re doing & how; The only zoomed-in shots are the before & after; No talking just background music ; Then in the description, where you expect their instructions, you get only stupidity… ie, like, “open laptop, remove wifi card.Put new one in the same way”. Wow, no sh**?! Idiots… Sadly, not exaggerated! So I just had to thank you, this is how it’s DONE! People should follow your example, something might get done (and done right) for a change!! Keep up the good work if this is ur thing! If not, it should be! Thanks again!
