Saltar al contenido principal
Introducción
This guide will teach you to remove and replace your trackpad.
  1. Use a Torx T4 screwdriver to unscrew the 9 5mm screws holding the cover in place.
    • Use a Torx T4 screwdriver to unscrew the 9 5mm screws holding the cover in place.
    • Use a Torx T4 screwdriver to unscrew the 8mm screw in the center.
    • When, reassembling, make sure not to tighten the screws too much or you may risk cracking the plastic cover.
  2. Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover. The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard. The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard.
    • Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
    • The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard.
  3. Use the Phillips #00 screwdriver to remove the four 3mm screws holding the battery in place. Be careful not to cross-thread the screws. Also, don't let the screws fall down into the laptop case.
    • Use the Phillips #00 screwdriver to remove the four 3mm screws holding the battery in place.
    • Be careful not to cross-thread the screws. Also, don't let the screws fall down into the laptop case.
  4. Kits de Reparación de Batería de iPhone
    Sólo $29.99
    Buy Now
    Sólo $29.99
    Buy Now
  5. Use the blue plastic opening tool to disconnect the battery cable. Make sure to apply pressure upward and try not to wiggle the connector from side to side, as this could damage the connector. Make sure to apply pressure upward and try not to wiggle the connector from side to side, as this could damage the connector.
    • Use the blue plastic opening tool to disconnect the battery cable.
    • Make sure to apply pressure upward and try not to wiggle the connector from side to side, as this could damage the connector.
  6. Use the Phillips #1 screwdriver to take off the three 3mm screws.
    • Use the Phillips #1 screwdriver to take off the three 3mm screws.
  7. Grip the blue tab and pull out. Careful to not pull too hard, there is a chance of damaging the tab.
    • Grip the blue tab and pull out.
    • Careful to not pull too hard, there is a chance of damaging the tab.
  8. Lift off the layer of tape from the trackpad. Lift off the layer of tape from the trackpad.
    • Lift off the layer of tape from the trackpad.
  9. Push out the trackpad.
    • Push out the trackpad.
Conclusión
Una persona más ha completado esta guía.
Chuefeng Vang
Miembro Desde 01/11/18
136 Reputación
1 Guía escrita
Equipo
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 17
Todo El Tiempo: 128
